Requesting help for Blender 2.57.1 python console script
World
Postby World » Tue Nov 22, 2011 6:44 pm
Hello
I have just started learning python (I have learned how to open the python console) so that I can do the following:
Code: Select all
//Loop through each .psk file in a folder
     //import current .psk file into scene
     //Get the name of the .psk file for export
     //export as .fbx into another folder and with name of the .psk file
     //clear the scene for the next .psk file
Unfortunately I haven't made much progress towards this, even after going through several web pages such as:
http://wiki.blender.org/index.php/Doc:2 ... in_Blender
http://www.blender.org/forum/viewtopic.php?t=16090
http://blenderartists.org/forum/archive ... 23590.html
http://www.macouno.com/2010/03/17/using-python-scripts/
http://vdrift.net/Forum/viewtopic.php?p=8214
So far I have:
Code: Select all
import bpy.ops
#Import a .psk file
bpy.ops.import_scene.psk(filepath="C:/BlenderImport/Example_01.psk")
#Export as .fbx file
bpy.ops.export_scene.fbx(filepath="C:/BlenderExport/Example_01.fbx")
#Clear existing
bpy.ops.wm.read_homefile()
Any help is appreciated, thank you.
World
Re: Requesting help for Blender 2.57.1 python console script
Postby World » Tue Nov 22, 2011 9:06 pm
Also where does one put the .py file on windows 7 and how can you run it in the python console
Tried typing: blender -P psk2fbx.py
Got:
File "<blender_console>", line 1
SyntaxError: invalid syntax
... or even better yet, is there something like a script area where you can just select to run this script
World
Help with variables for filepath
Postby World » Tue Nov 22, 2011 9:43 pm
So I've been researching even more, and thought I had it this time.
Code: Select all
import bpy
import bpy.ops
import os
def GetAllPSK(dir_name):
    pskList = []
    for file in os.listdir(dir_name):
        dirfile = os.path.join(dir_name, file)
        pskList.append(dirfile)
    return pskList
if __name__ == "__main__":
    pskList = GetAllPSK("C:/BlenderImport")
    for p in pskList:
        #Import a .psk file
        bpy.ops.import_scene.psk(filepath=p)
        #Select all
        bpy.ops.object.select_all()
        bpy.ops.export_scene.fbx(filepath=p)
        #Clear existing
Sadly, it seems that for filepath I'm getting this error:
Code: Select all
Python Script fail, look in the console for now ...
Could someone please help fix my code
World
Not sure what to do
Postby World » Tue Nov 22, 2011 11:30 pm
Well, after much trial and error
Code: Select all
import bpy
import bpy.ops
import os
import string
    pskList = []
        dirfile = file.replace('.psk','')
    return pskList
    pskList = GetAllPSK("C:/BlenderImport/")
    for p in pskList:
        #Import a .psk file
        bpy.ops.import_scene.psk(filepath="C:/BlenderImport/" + p + ".psk")
        #Select all
        bpy.ops.export_scene.fbx(filepath="C:/BlenderExport/" + p + ".fbx")
        #Delete Mesh
        bpy.ops.object.delete()
Seems I can import the mesh, but it gives an error of check console yet again and my script stops there
Again, I'm open to suggestions :(
stiv
Postby stiv » Wed Nov 23, 2011 12:43 am
As always, knowing the exact error message is useful for debugging problems.
Otherwise, you get advice like:
1) read the error message
2) identify and correct the problem
World
Postby World » Wed Nov 23, 2011 6:04 am
stiv wrote:As always, knowing the exact error message is useful for debugging problems.
The exact error I get in the text editor is:
Code: Select all
Error, python script fail, look in the console for now ...
Do you know how to do enable this "console", when I start blender all I have is blender itself, no log screen or anything to go with it.
ldo
Postby ldo » Fri Nov 25, 2011 10:05 am
On Windows, Blender runs from a console window. The error messages should appear in that console window.
brasshat
Postby brasshat » Fri Nov 25, 2011 7:56 pm
World wrote:
stiv wrote:
Code: Select all
On my installation of Blender 2.60a, one activates the Blender console window by selecting from the drop down menu associated with "Help", the item "toggle system console".
ns
carrollh
Postby carrollh » Wed Jun 06, 2012 11:43 pm
In 2.53 you need to specify one of the following before you enter the filepath:
'INVOKE_DEFAULT', 'INVOKE_REGION_WIN', 'INVOKE_REGION_CHANNELS', 'INVOKE_REGION_PREVIEW', 'INVOKE_AREA', 'INVOKE_SCREEN', 'EXEC_DEFAULT', 'EXEC_REGION_WIN', 'EXEC_REGION_CHANNELS', 'EXEC_REGION_PREVIEW', 'EXEC_AREA', 'EXEC_SCREEN'
So in short, you need to load each of your files using:
bpy.ops.import_scene.psk(<choice from above>, filepath=<path + filename>)
Both of the arguments required is a string. I tested 'EXEC_DEFAULT' as the first and it did what I wanted. I think 2.6 uses python 3, so this probably won't work the same.
CoDEmanX
Postby CoDEmanX » Thu Jun 07, 2012 2:34 am
Return to “Python”
