Previous Thread  Next Thread
chat icon i can't found any menu and the button one the toolbar
yaxinhoo
Posted: Sun Dec 04, 2011 6:57 pm
i had clone the source form svn trunk . use cmake to create project. then build and install it . but when i run the blender. the app start normally except the menu . i can't found any menu and the button one the toolbar. why ? anyone can tell me ?
vs2008.
cmake build.
winxp/win7 all got the same result.
i had run it with administrator
this is the error of picture.
-- moderator note: bad link deleted
stiv
Posted: Mon Dec 05, 2011 7:21 pm
The usual cause for this is either running blender from the build directory rather than the install directory, or not doing the 'make install' step.
yaxinhoo
Posted: Tue Dec 06, 2011 12:48 am
[img]http://img8.ph.126.net/5sJ4cKlJswBPohhiRxhlVw==/1547267946995598048.jpg[/img]
stiv
Posted: Tue Dec 06, 2011 2:54 am
Run blender from the install dir. NOT the build dir.
yaxinhoo
Posted: Tue Dec 06, 2011 1:47 pm
what is the difference , i use vs2008 build&install , so the build dir is the install dir.
or where is the install dir ?
stiv
Posted: Tue Dec 06, 2011 4:20 pm
The build dir is the one that does not have the python scripts for the user interface.
Judging from your picture, the install dir is the one called INSTALL.dir.
yaxinhoo
Posted: Tue Dec 13, 2011 9:40 pm
thanks for you reply . i am still confused.
this is my install.dir , it can't found any file .
BAD LINK DELETED
but in my bin/debug dir , i found python script.
BAD LINK DELETED
so i thank it's not less python script. but for other things.
this is my version
http://photo.163.com/yaxinhoo@hotmail.com/big/#aid=232458740&id=7392499521
Tehrasha
Posted: Tue Dec 13, 2011 11:57 pm
Before you do too much more, you better find a better image host.
I cannot see any of the images you have been posting.
I only get this...
stiv
Posted: Wed Dec 14, 2011 1:18 am
At the risk of repeating myself:
You need to run Blender FROM THE INSTALL DIR.
If there is nothing in the install dir, you forgot the 'make install' step. (or the build failed)
-- moderator's note: as Tehrasha said, the image links are bad and have been removed.
Tehrasha
Posted: Wed Dec 14, 2011 1:39 am
yaxinhoo
Posted: Sat Dec 17, 2011 2:17 pm
what is the meaning of ,
[img]http://img7.ph.126.net/E4HAcAStasRRfI8YgWdqlQ==/2710322550764055157.jpg[/img]
i install the python27 and python26.
stiv
Posted: Sat Dec 17, 2011 6:57 pm
This does not matter for new Blender (2.50 and above). New Blender uses Python 3 and comes with its own copy.
yaxinhoo
Posted: Sun Dec 18, 2011 6:27 am
ok , my cmake generate solution alway install the path to bin/debug but not install.dir/debug
yaxinhoo
Posted: Sun Dec 18, 2011 6:43 am
1>------ Build started: Project: INSTALL, Configuration: Debug Win32 ------
1>
1>Performing Post-Build Event...
1>-- Install configuration: "Debug"
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_curve_aceous_galore.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_curve_ivygen.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_curve_sapling
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_curve_sapling/presets
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_curve_sapling/presets/black_tupelo.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_curve_sapling/presets/ca_black_oak.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_curve_sapling/presets/quaking_aspen.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_curve_sapling/presets/weeping_willow.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_curve_sapling/utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_curve_sapling/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_curve_torus_knots.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_ant_landscape.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_BoltFactory
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_BoltFactory/Boltfactory.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_BoltFactory/createMesh.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_BoltFactory/presets
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_BoltFactory/presets/M10.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_BoltFactory/presets/M12.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_BoltFactory/presets/M3.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_BoltFactory/presets/M4.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_BoltFactory/presets/M5.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_BoltFactory/presets/M6.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_BoltFactory/presets/M8.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_BoltFactory/preset_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_BoltFactory/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_extra_objects
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_extra_objects/add_mesh_3d_function_surface.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_extra_objects/add_mesh_extra_objects.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_extra_objects/add_mesh_gears.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_extra_objects/add_mesh_gemstones.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_extra_objects/add_mesh_polysphere.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_extra_objects/add_mesh_pyramid.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_extra_objects/add_mesh_supertoroid.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_extra_objects/add_mesh_twisted_torus.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_extra_objects/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_pipe_joint.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/add_mesh_solid.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/animation_add_corrective_shape_key.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/animation_animall.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/animation_rotobezier.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/curve_simplify.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/development_api_navigator.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/development_icon_get.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/game_engine_save_as_runtime.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_acclaim
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_acclaim/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_bvh
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_bvh/export_bvh.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_bvh/import_bvh.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_bvh/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_c3d
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_c3d/import_c3d.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_c3d/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_camera.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_nuke_chan
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_nuke_chan/export_nuke_chan.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_nuke_chan/import_nuke_chan.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_anim_nuke_chan/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_coat3D
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_coat3D/coat.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_coat3D/tex.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_coat3D/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_convert_image_to_mesh_img
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_convert_image_to_mesh_img/import_img.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_convert_image_to_mesh_img/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_curve_svg
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_curve_svg/import_svg.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_curve_svg/svg_colors.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_curve_svg/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_export_after_effects.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_export_directx_x.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_export_pc2.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_export_unreal_psk_psa.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_import_gimp_image_to_scene.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_import_images_as_planes.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_import_scene_dxf.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_import_scene_lwo.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_import_scene_mhx.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_import_scene_unreal_psk.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_pdb
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_pdb/atom_info.dat
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_pdb/import_pdb.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_pdb/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_ply
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_ply/export_ply.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_ply/import_ply.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_ply/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_raw
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_raw/export_raw.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_raw/import_raw.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_raw/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_stl
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_stl/blender_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_stl/stl_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_stl/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_uv_layout
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_uv_layout/export_uv_eps.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_uv_layout/export_uv_png.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_uv_layout/export_uv_svg.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_mesh_uv_layout/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_3ds
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_3ds/export_3ds.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_3ds/import_3ds.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_3ds/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_fbx
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_fbx/export_fbx.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_fbx/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_m3
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_m3/import_m3.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_m3/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_map
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_map/export_map.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_map/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_obj
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_obj/export_obj.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_obj/import_obj.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_obj/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_x3d
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_x3d/export_x3d.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_x3d/import_x3d.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_scene_x3d/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_shape_mdd
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_shape_mdd/export_mdd.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_shape_mdd/import_mdd.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/io_shape_mdd/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/light_field_tools
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/light_field_tools/light_field_tools.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/light_field_tools/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mesh_bsurfaces.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mesh_inset
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mesh_inset/geom.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mesh_inset/model.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mesh_inset/offset.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mesh_inset/triquad.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mesh_inset/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mesh_looptools.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mesh_relax.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mocap
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mocap/mocap_constraints.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mocap/mocap_tools.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mocap/retarget.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/mocap/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/modules
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/modules/add_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/modules/constants_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/modules/cursor_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/modules/extensions_framework
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/modules/extensions_framework/ui.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/modules/extensions_framework/util.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/modules/extensions_framework/validate.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/modules/extensions_framework/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/modules/geometry_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/modules/misc_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/modules/ui_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/balancing.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/client.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/master.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/master_html.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/model.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/netrender.css
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/netrender.js
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/operators.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/repath.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/slave.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/thumbnail.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/ui.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/versioning.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/netrender/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/object_add_chain.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/object_animrenderbake.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/object_cloud_gen.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/object_fracture
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/object_fracture/data.blend
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/object_fracture/fracture_ops.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/object_fracture/fracture_setup.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/object_fracture/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/object_grease_scatter.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/paint_palette.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/render_povray
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/render_povray/render.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/render_povray/ui.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/render_povray/update_files.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/render_povray/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/render_renderfarmfi.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/CREDITS
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/generate.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/metarigs
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/metarigs/human.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/metarigs/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/metarig_menu.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/README
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/basic
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/basic/copy.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/basic/copy_chain.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/basic/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/biped
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/biped/arm
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/biped/arm/deform.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/biped/arm/fk.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/biped/arm/ik.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/biped/arm/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/biped/leg
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/biped/leg/deform.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/biped/leg/fk.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/biped/leg/ik.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/biped/leg/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/biped/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/finger.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/misc
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/misc/delta.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/misc/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/neck_short.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/palm.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/spine.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rigs/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/rig_ui_template.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/ui.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/rigify/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/space_view3d_3d_navigation.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/space_view3d_copy_attributes.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/space_view3d_materials_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/space_view3d_math_vis
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/space_view3d_math_vis/draw.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/space_view3d_math_vis/utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/space_view3d_math_vis/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/space_view3d_panel_measure.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/space_view3d_screencast_keys.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/space_view3d_spacebar_menu.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/system_blend_info.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/system_demo_mode
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/system_demo_mode/config.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/system_demo_mode/demo_mode.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/system_demo_mode/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/system_property_chart.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons/texture_paint_layer_manager.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/addons_contrib
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/addon_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/animsys_refactor.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/blend_render_info.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy/ops.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy/path.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy/utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpyml.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpyml_ui.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy_extras
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy_extras/anim_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy_extras/image_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy_extras/io_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy_extras/keyconfig_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy_extras/mesh_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy_extras/object_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy_extras/view3d_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy_extras/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/bpy_types.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/console
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/console/complete_calltip.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/console/complete_import.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/console/complete_namespace.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/console/intellisense.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/console/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/console_python.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/console_shell.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/graphviz_export.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/keyingsets_utils.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/rna_info.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/rna_prop_ui.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/modules/sys_info.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/APS-C_DSLR.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Blender.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Canon_1100D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Canon_1D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Canon_1DS.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Canon_500D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Canon_550D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Canon_5D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Canon_600D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Canon_60D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Canon_7D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/full_frame_35mm_film.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/micro_four_thirds.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Nikon_D300S.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Nikon_D3100.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Nikon_D3S.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Nikon_D5000.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Nikon_D5100.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Nikon_D7000.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Nikon_D90.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Red_Epic.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Red_One_2K.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Red_One_3K.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Red_One_4K.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/Sony_A55.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/super_16_film.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/camera/super_35_film.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/cloth
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/cloth/cotton.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/cloth/denim.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/cloth/leather.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/cloth/rubber.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/cloth/silk.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/cycles
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/cycles/integrator
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/cycles/integrator/direct_light.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/cycles/integrator/full_global_illumination.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/cycles/integrator/limited_global_illumination.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/ffmpeg
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/ffmpeg/DV.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/ffmpeg/DVD.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/ffmpeg/h264.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/ffmpeg/SVCD.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/ffmpeg/theora.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/ffmpeg/VCD.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/ffmpeg/xvid.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/framerate
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/framerate/23.98.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/framerate/24.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/framerate/25.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/framerate/29.97.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/framerate/30.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/framerate/50.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/framerate/59.94.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/framerate/60.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/framerate/Custom.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/interaction
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/interaction/blender.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/interaction/maya.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/keyconfig
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/keyconfig/maya.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/render
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/render/DVCPRO_HD_1080p.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/render/DVCPRO_HD_720p.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/render/HDTV_1080p.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/render/HDTV_720p.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/render/HDV_1080p.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/render/HDV_NTSC_1080p.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/render/HDV_PAL_1080p.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/render/TV_NTSC_16_colon_9.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/render/TV_NTSC_4_colon_3.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/render/TV_PAL_16_colon_9.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/render/TV_PAL_4_colon_3.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sss
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sss/apple.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sss/chicken.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sss/cream.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sss/ketchup.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sss/marble.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sss/potato.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sss/skim_milk.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sss/skin1.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sss/skin2.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sss/whole_milk.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sunsky
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sunsky/classic.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sunsky/desert.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/sunsky/mountain.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Blender.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Canon_1100D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Canon_1D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Canon_1DS.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Canon_500D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Canon_550D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Canon_5D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Canon_600D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Canon_60D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Canon_7D.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Nikon_D300S.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Nikon_D3100.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Nikon_D35.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Nikon_D5000.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Nikon_D5100.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Nikon_D7000.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Nikon_D90.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Red_Epic.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Red_One_2K.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Red_One_3K.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Red_One_4K.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_camera/Sony_A55.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_settings
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_settings/blurry_footage.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_settings/default.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_settings/fast_motion.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_track_color
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_track_color/default.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_track_color/far_plane.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/presets/tracking_track_color/near_plane.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/add_mesh_torus.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/anim.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/clip.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/console.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/image.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/mesh.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/object.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/object_align.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/object_quick_effects.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/object_randomize_transform.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/presets.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/screen_play_rendered_anim.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/sequencer.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/uvcalc_follow_active.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/uvcalc_lightmap.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/uvcalc_smart_project.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/vertexpaint_dirt.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/view3d.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/wm.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_operators/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_animviz.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_data_armature.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_data_bone.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_data_camera.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_data_curve.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_data_empty.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_data_lamp.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_data_lattice.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_data_mesh.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_data_metaball.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_data_modifier.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_data_speaker.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_game.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_material.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_object.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_object_constraint.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_particle.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_physics_cloth.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_physics_common.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_physics_dynamicpaint.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_physics_field.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_physics_fluid.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_physics_smoke.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_physics_softbody.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_render.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_scene.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_texture.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/properties_world.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_clip.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_console.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_dopesheet.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_filebrowser.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_graph.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_image.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_info.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_logic.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_nla.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_node.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_outliner.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_sequencer.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_text.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_time.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_userpref.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_userpref_keymap.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_view3d.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/space_view3d_toolbar.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/bl_ui/__init__.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/startup/keyingsets_builtins.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/addon_add_object.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/background_job.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/batch_export.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/builtin_keyingset.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/driver_functions.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/gamelogic.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/gamelogic_basic.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/gamelogic_module.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/operator_export.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/operator_mesh_add.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/operator_modal.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/operator_modal_draw.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/operator_modal_timer.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/operator_modal_view3d.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/operator_simple.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/operator_uv.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/ui_menu.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/ui_menu_simple.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/scripts/templates/ui_panel_simple.py
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ar
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ar/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ar/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/bg
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/bg/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/bg/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ca
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ca/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ca/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/cs
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/cs/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/cs/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/de
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/de/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/de/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/el
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/el/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/el/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/es
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/es/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/es/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/es_ES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/es_ES/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/es_ES/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/es_MX
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/es_MX/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/es_MX/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/fa
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/fa/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/fa/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/fi
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/fi/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/fi/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/fr
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/fr/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/fr/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/id
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/id/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/id/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/it
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/it/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/it/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ja
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ja/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ja/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ne
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ne/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ne/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/pl
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/pl/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/pl/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/pt_BR
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/pt_BR/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/pt_BR/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ru
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ru/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/ru/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/sr
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/sr/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/sr/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/sr@latin
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/sr@latin/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/sr@latin/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/sv
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/sv/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/sv/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/zh_CN
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/zh_CN/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/zh_CN/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/zh_TW
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/zh_TW/LC_MESSAGES
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/locale/zh_TW/LC_MESSAGES/blender.mo
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/fonts
1>-- Installing: I:/Build/blender/bin/Debug/2.61/datafiles/fonts/droidsans.ttf.gz
1>-- Up-to-date: I:/Build/blender/bin/Debug/GPL-license.txt
1>-- Up-to-date: I:/Build/blender/bin/Debug/Python-license.txt
1>-- Up-to-date: I:/Build/blender/bin/Debug/copyright.txt
1>-- Up-to-date: I:/Build/blender/bin/Debug/readme.html
1>-- Up-to-date: I:/Build/blender/bin/Debug/gnu_gettext.dll
1>-- Up-to-date: I:/Build/blender/bin/Debug/iconv.dll
1>-- Up-to-date: I:/Build/blender/bin/Debug/python32_d.dll
1>creating I:/Build/blender/bin/Debug/2.61/python/lib
1>done creating dir
1>--------- 0 0 7650 Aug 17 18:52 2010 abc.py
1>--------- 0 0 30603 May 8 12:24 2009 aifc.py
1>--------- 0 0 475 Jun 4 11:21 2009 antigravity.py
1>--------- 0 0 88365 Jan 31 6:19 2011 argparse.py
1>--------- 0 0 12158 Jan 25 15:36 2011 ast.py
1>--------- 0 0 12133 Jul 7 23:04 2008 asynchat.py
1>--------- 0 0 20825 Feb 12 8:01 2011 asyncore.py
1>--------- 0 0 14091 Nov 12 14:09 2010 base64.py
1>--------- 0 0 21264 Jan 6 18:49 2011 bdb.py
1>--------- 0 0 13492 Aug 3 14:08 2009 binhex.py
1>--------- 0 0 2595 Apr 1 11:51 2009 bisect.py
1>--------- 0 0 108544 Mar 4 18:08 2011 bz2_d.pyd
1>--------- 0 0 22677 Oct 20 12:54 2010 calendar.py
1>--------- 0 0 34484 Jan 15 7:08 2011 cgi.py
1>--------- 0 0 11947 Apr 12 13:48 2009 cgitb.py
1>--------- 0 0 5377 Aug 30 19:19 2007 chunk.py
1>--------- 0 0 14803 Sep 9 21:53 2010 cmd.py
1>--------- 0 0 9574 Nov 26 11:46 2009 code.py
1>--------- 0 0 35338 Dec 3 12:06 2010 codecs.py
1>--------- 0 0 5994 Oct 18 18:32 2009 codeop.py
1>--------- 0 0 36703 Jan 3 20:44 2011 collections.py
1>--------- 0 0 3691 Jan 30 21:39 2009 colorsys.py
1>--------- 0 0 9633 Feb 8 6:36 2011 compileall.py
1>d-------- 0 0 0 Mar 7 3:57 2011 concurrent/
1>d-------- 0 0 0 Mar 7 3:57 2011 concurrent/futures/
1>--------- 0 0 15075 Jan 3 18:07 2011 concurrent/futures/process.py
1>--------- 0 0 4665 Sep 19 21:55 2010 concurrent/futures/thread.py
1>--------- 0 0 19248 Dec 29 15:14 2010 concurrent/futures/_base.py
1>--------- 0 0 800 Sep 19 21:55 2010 concurrent/futures/__init__.py
1>--------- 0 0 38 Sep 19 21:55 2010 concurrent/__init__.py
1>--------- 0 0 48851 Dec 18 15:56 2010 configparser.py
1>--------- 0 0 3379 Jan 9 3:55 2011 contextlib.py
1>--------- 0 0 10331 Sep 5 11:46 2010 copy.py
1>--------- 0 0 6633 Jun 14 16:53 2008 copyreg.py
1>--------- 0 0 6350 Aug 3 6:20 2010 cProfile.py
1>--------- 0 0 16122 Oct 28 1:27 2010 csv.py
1>d-------- 0 0 0 Mar 7 3:58 2011 ctypes/
1>d-------- 0 0 0 Mar 7 3:57 2011 ctypes/macholib/
1>--------- 0 0 4907 Aug 30 21:47 2007 ctypes/macholib/dyld.py
1>--------- 0 0 1828 Jul 14 5:49 2007 ctypes/macholib/dylib.py
1>--------- 0 0 84 Mar 9 19:35 2006 ctypes/macholib/fetch_macholib
1>--------- 0 0 74 Mar 9 19:35 2006 ctypes/macholib/fetch_macholib.bat
1>--------- 0 0 2201 Jul 14 5:49 2007 ctypes/macholib/framework.py
1>--------- 0 0 296 Mar 9 19:35 2006 ctypes/macholib/README.ctypes
1>--------- 0 0 154 Jul 14 5:49 2007 ctypes/macholib/__init__.py
1>d-------- 0 0 0 Mar 7 3:58 2011 ctypes/test/
1>--------- 0 0 681 May 24 11:26 2008 ctypes/test/runtests.py
1>--------- 0 0 2051 Jul 1 17:06 2009 ctypes/test/test_anon.py
1>--------- 0 0 4151 Jul 28 17:36 2010 ctypes/test/test_arrays.py
1>--------- 0 0 1738 Jul 1 17:06 2009 ctypes/test/test_array_in_pointer.py
1>--------- 0 0 6523 Jul 1 17:06 2009 ctypes/test/test_as_parameter.py
1>--------- 0 0 8643 Jul 28 17:36 2010 ctypes/test/test_bitfields.py
1>--------- 0 0 2074 Jul 28 18:15 2010 ctypes/test/test_buffers.py
1>--------- 0 0 1190 Aug 1 4:52 2010 ctypes/test/test_bytes.py
1>--------- 0 0 10346 Jul 1 17:06 2009 ctypes/test/test_byteswap.py
1>--------- 0 0 7654 Feb 1 15:08 2011 ctypes/test/test_callbacks.py
1>--------- 0 0 3222 Jul 28 17:36 2010 ctypes/test/test_cast.py
1>--------- 0 0 7622 Jul 28 17:36 2010 ctypes/test/test_cfuncs.py
1>--------- 0 0 995 Jul 1 17:06 2009 ctypes/test/test_checkretval.py
1>--------- 0 0 533 Dec 19 20:07 2007 ctypes/test/test_delattr.py
1>--------- 0 0 477 Mar 9 19:35 2006 ctypes/test/test_errcheck.py
1>--------- 0 0 2302 Jul 28 17:36 2010 ctypes/test/test_errno.py
1>--------- 0 0 2470 Jul 1 17:06 2009 ctypes/test/test_find.py
1>--------- 0 0 2485 Jul 1 17:06 2009 ctypes/test/test_frombuffer.py
1>--------- 0 0 3915 Sep 5 12:24 2009 ctypes/test/test_funcptr.py
1>--------- 0 0 12624 Sep 5 12:24 2009 ctypes/test/test_functions.py
1>--------- 0 0 1023 Sep 5 12:24 2009 ctypes/test/test_incomplete.py
1>--------- 0 0 1040 Jul 1 17:06 2009 ctypes/test/test_init.py
1>--------- 0 0 97 Mar 9 19:35 2006 ctypes/test/test_integers.py
1>--------- 0 0 2626 Jul 28 17:36 2010 ctypes/test/test_internals.py
1>--------- 0 0 4022 Nov 21 13:04 2010 ctypes/test/test_keeprefs.py
1>--------- 0 0 1005 Jul 28 17:36 2010 ctypes/test/test_libc.py
1>--------- 0 0 4097 Aug 1 4:52 2010 ctypes/test/test_loading.py
1>--------- 0 0 1593 Jul 1 17:06 2009 ctypes/test/test_macholib.py
1>--------- 0 0 3265 Sep 5 12:24 2009 ctypes/test/test_memfunctions.py
1>--------- 0 0 8795 Jul 1 17:06 2009 ctypes/test/test_numbers.py
1>--------- 0 0 1765 Jul 28 17:36 2010 ctypes/test/test_objects.py
1>--------- 0 0 6532 Sep 1 9:45 2010 ctypes/test/test_parameters.py
1>--------- 0 0 7487 Jul 1 17:06 2009 ctypes/test/test_pep3118.py
1>--------- 0 0 2200 Jul 1 17:06 2009 ctypes/test/test_pickling.py
1>--------- 0 0 6273 Sep 5 12:24 2009 ctypes/test/test_pointers.py
1>--------- 0 0 6784 Jul 28 17:36 2010 ctypes/test/test_prototypes.py
1>--------- 0 0 3066 Jul 28 17:36 2010 ctypes/test/test_python_api.py
1>--------- 0 0 2832 Aug 1 4:52 2010 ctypes/test/test_random_things.py
1>--------- 0 0 2481 Jul 1 17:06 2009 ctypes/test/test_refcounts.py
1>--------- 0 0 842 Jul 28 17:36 2010 ctypes/test/test_repr.py
1>--------- 0 0 1567 Jul 28 17:36 2010 ctypes/test/test_returnfuncptrs.py
1>--------- 0 0 1289 Jul 1 17:06 2009 ctypes/test/test_simplesubclasses.py
1>--------- 0 0 815 Mar 1 22:59 2010 ctypes/test/test_sizes.py
1>--------- 0 0 6093 Sep 5 12:24 2009 ctypes/test/test_slicing.py
1>--------- 0 0 2484 Jul 28 17:36 2010 ctypes/test/test_stringptr.py
1>--------- 0 0 7126 Oct 3 5:25 2010 ctypes/test/test_strings.py
1>--------- 0 0 14717 Jul 28 17:36 2010 ctypes/test/test_structures.py
1>--------- 0 0 1503 Jul 1 17:06 2009 ctypes/test/test_struct_fields.py
1>--------- 0 0 1215 Jul 1 17:06 2009 ctypes/test/test_unaligned_structures.py
1>--------- 0 0 1911 Jul 28 18:15 2010 ctypes/test/test_unicode.py
1>--------- 0 0 3509 Jul 1 17:06 2009 ctypes/test/test_values.py
1>--------- 0 0 1842 Jul 1 17:06 2009 ctypes/test/test_varsize_struct.py
1>--------- 0 0 3099 Jun 22 10:00 2010 ctypes/test/test_win32.py
1>--------- 0 0 7126 Sep 26 15:35 2009 ctypes/test/__init__.py
1>--------- 0 0 8575 Sep 16 7:06 2010 ctypes/util.py
1>--------- 0 0 5628 Sep 29 15:08 2010 ctypes/wintypes.py
1>--------- 0 0 1783 Jul 14 5:49 2007 ctypes/_endian.py
1>--------- 0 0 16819 Jul 28 18:15 2010 ctypes/__init__.py
1>d-------- 0 0 0 Mar 7 3:58 2011 curses/
1>--------- 0 0 2607 Aug 30 12:51 2003 curses/ascii.py
1>--------- 0 0 5634 Feb 9 23:37 2007 curses/has_key.py
1>--------- 0 0 156 Jul 19 0:16 2004 curses/panel.py
1>--------- 0 0 7339 Jul 16 21:43 2008 curses/textpad.py
1>--------- 0 0 1632 Aug 3 13:44 2010 curses/wrapper.py
1>--------- 0 0 1875 Feb 27 2:18 2008 curses/__init__.py
1>--------- 0 0 73498 Jan 8 18:13 2011 datetime.py
1>d-------- 0 0 0 Mar 7 3:58 2011 dbm/
1>--------- 0 0 9603 Dec 5 3:14 2010 dbm/dumb.py
1>--------- 0 0 72 Jun 14 16:53 2008 dbm/gnu.py
1>--------- 0 0 70 Jun 14 16:53 2008 dbm/ndbm.py
1>--------- 0 0 5695 Jul 30 10:26 2010 dbm/__init__.py
1>--------- 0 0 222588 Feb 2 17:54 2011 decimal.py
1>--------- 0 0 81327 Dec 16 14:18 2010 difflib.py
1>--------- 0 0 9840 Sep 11 8:08 2010 dis.py
1>d-------- 0 0 0 Mar 7 3:58 2011 distutils/
1>--------- 0 0 6489 Dec 16 14:26 2010 distutils/archive_util.py
1>--------- 0 0 15015 Jul 23 6:50 2010 distutils/bcppcompiler.py
1>--------- 0 0 47631 Nov 6 17:51 2010 distutils/ccompiler.py
1>--------- 0 0 19105 Jul 23 6:50 2010 distutils/cmd.py
1>d-------- 0 0 0 Mar 7 3:58 2011 distutils/command/
1>--------- 0 0 5050 Jul 23 6:50 2010 distutils/command/bdist.py
1>--------- 0 0 4736 Jul 23 6:50 2010 distutils/command/bdist_dumb.py
1>--------- 0 0 35137 Aug 31 8:05 2010 distutils/command/bdist_msi.py
1>--------- 0 0 20166 Nov 6 20:10 2010 distutils/command/bdist_rpm.py
1>--------- 0 0 14894 Nov 6 17:51 2010 distutils/command/bdist_wininst.py
1>--------- 0 0 5486 Jul 23 6:50 2010 distutils/command/build.py
1>--------- 0 0 8100 Sep 8 16:11 2010 distutils/command/build_clib.py
1>--------- 0 0 32447 Dec 16 15:07 2010 distutils/command/build_ext.py
1>--------- 0 0 17033 Jul 23 6:50 2010 distutils/command/build_py.py
1>--------- 0 0 5066 Jul 23 6:50 2010 distutils/command/build_scripts.py
1>--------- 0 0 5369 Oct 4 8:18 2010 distutils/command/check.py
1>--------- 0 0 2851 Aug 30 21:52 2007 distutils/command/clean.py
1>--------- 0 0 633 Aug 30 21:52 2007 distutils/command/command_template
1>--------- 0 0 13166 Jul 23 6:50 2010 distutils/command/config.py
1>--------- 0 0 27478 Nov 25 21:46 2010 distutils/command/install.py
1>--------- 0 0 2902 Apr 1 15:37 2009 distutils/command/install_data.py
1>--------- 0 0 2587 Dec 13 22:49 2006 distutils/command/install_egg_info.py
1>--------- 0 0 1381 Apr 1 15:37 2009 distutils/command/install_headers.py
1>--------- 0 0 8318 Oct 26 17:08 2009 distutils/command/install_lib.py
1>--------- 0 0 2102 Aug 30 21:52 2007 distutils/command/install_scripts.py
1>--------- 0 0 11765 Jul 23 6:50 2010 distutils/command/register.py
1>--------- 0 0 17301 Sep 12 9:28 2010 distutils/command/sdist.py
1>--------- 0 0 7386 Nov 6 17:51 2010 distutils/command/upload.py
1>--------- 0 0 61440 Jul 16 20:02 2008 distutils/command/wininst-6.0.exe
1>--------- 0 0 65536 Jul 16 20:02 2008 distutils/command/wininst-7.1.exe
1>--------- 0 0 61440 Jan 21 15:25 2009 distutils/command/wininst-8.0.exe
1>--------- 0 0 224256 Jan 30 7:08 2009 distutils/command/wininst-9.0-amd64.exe
1>--------- 0 0 196096 Jan 30 7:08 2009 distutils/command/wininst-9.0.exe
1>---------
yaxinhoo
Posted: Sun Dec 18, 2011 6:46 am
then when i run blender , it tell me python line lookup fail.
i copy the /bin/debug dir to install.dir/debug . run the blender but got the same result.
Goto page 1, 2  Next
Jump to:
