Previous Thread  Next Thread
chat icon built blender missing menus ,with the latest version
kfqcome
Posted: Tue Jan 17, 2012 6:14 am
i built the blender of the latest version successfully,but when i run it,there are many menus lost ,and have many errors output in the command window ,as below:
found bundled python: H:\open\blender\vc2008\bin\Debug\2.61\python
search for unknown operator 'WM_OT_context_set_enum', 'WM_OT_context_set_enum'
RNA_string_set: OperatorProperties.data_path not found.
RNA_string_set: OperatorProperties.value not found.
search for unknown operator 'RENDER_OT_play_rendered_anim', 'RENDER_OT_play_rendered_anim'
search for unknown operator 'WM_OT_context_toggle', 'WM_OT_context_toggle'
search for unknown operator 'WM_OT_context_cycle_enum', 'WM_OT_context_cycle_enum'
search for unknown operator 'OBJECT_OT_select_hierarchy', 'OBJECT_OT_select_hierarchy'
RNA_enum_set_identifier: OperatorProperties.direction not found.
RNA_boolean_set: OperatorProperties.extend not found.
search for unknown operator 'OBJECT_OT_subdivision_set', 'OBJECT_OT_subdivision_set'
RNA_int_set: OperatorProperties.level not found.
search for unknown operator 'WM_OT_context_toggle_enum', 'WM_OT_context_toggle_enum'
RNA_string_set: OperatorProperties.value_1 not found.
RNA_string_set: OperatorProperties.value_2 not found.
search for unknown operator 'VIEW3D_OT_edit_mesh_extrude_move_normal', 'VIEW3D_OT_edit_mesh_extrude_move_normal'
RNA_boolean_set: OperatorProperties.relative not found.
search for unknown operator 'BRUSH_OT_active_index_set', 'BRUSH_OT_active_index_set'
RNA_string_set: OperatorProperties.mode not found.
RNA_int_set: OperatorProperties.index not found.
search for unknown operator 'WM_OT_context_menu_enum', 'WM_OT_context_menu_enum'
search for unknown operator 'WM_OT_context_cycle_int', 'WM_OT_context_cycle_int'
RNA_boolean_set: OperatorProperties.reverse not found.
search for unknown operator 'SEQUENCER_OT_cut_multicam', 'SEQUENCER_OT_cut_multicam'
RNA_int_set: OperatorProperties.camera not found.
search for unknown operator 'WM_OT_context_set_int', 'WM_OT_context_set_int'
RNA_int_set: OperatorProperties.value not found.
search for unknown operator 'CONSOLE_OT_execute', 'CONSOLE_OT_execute'
search for unknown operator 'CONSOLE_OT_autocomplete', 'CONSOLE_OT_autocomplete'
thanks.
[/img]
kfqcome
Posted: Tue Jan 17, 2012 6:26 am
this is user-interface displayed
stiv
Posted: Tue Jan 17, 2012 8:16 am
Typically, this comes from running from the build directory, rather than the install directory.
If you are using cmake (you did not mention the build system), do not forget the 'make install' step.
Jump to:
