Posted: Sat Mar 17, 2012 10:24 am
Hi just using Blender 2.6, seem the custom operators aren't working for me...
Just tested with the pingpong script
import bpy
# version 1.3.0
# tested on 31315
class OBJECT_PT_pingpong(bpy.types.Panel):
bl_space_type = "PROPERTIES"
bl_region_type = "WINDOW"
bl_context = "object"
bl_label = "Ping Pong"
display = 0
def draw_header(self, context):
layout = self.layout
layout.label(text="", icon="PHYSICS")
def draw(self, context):
row = layout.row()
split = row.split(percentage=0.5)
colL = split.column()
colR = split.column()
if self.display == 0:
colL.operator("pipo", text="Ping")
else:
colR.operator("pipo", text="Pong")
bpy.utils.register_class(OBJECT_PT_pingpong)
This is all i get:
all my custom buttons are doing the same, just the txt and nothing to click. Any ideas? Is this 2.6 problem?
_________________
....interesting....
Posted: Sun Mar 18, 2012 11:05 am
Posted: Sun Mar 18, 2012 6:59 pm
lol! sorry my bad....shoulda put the whole script. "pipo" is the class (Operator) id_name
class OBJECT_OT_pingpong(bpy.types.Operator):
bl_label = "PingPong operator"
bl_idname = "pipo"
bl_description = "Move the ball"
import bpy
self.report("INFO", "Moving the ball")
bpy.types.OBJECT_PT_pingpong.display = 1 - bpy.types.OBJECT_PT_pingpong.display
return{"FINISHED"}
thats what the previous def calls on.
_________________
....interesting....
Posted: Mon Mar 19, 2012 1:49 am
Your bl_idname probably needs a prefix which is one of the valid subcategories defined in bpy.ops, e.g. “object.pipo” rather than just “pipo”.
Also I wouldn’t bother giving your class a magic
xx_OT_
xx-type name—it serves no purpose.
Posted: Mon Mar 19, 2012 7:42 am
Hmm that didnt work for me, im wondering do i have to register the operator class as well?
Well anyway that didnt work either. Its strange if i use any of the operators already created e.g. "object.armature_add" then it pops out a button with any problemos.
Seems rather wierd was working on previous versions.
fully agree with the whole magic thing...i wondered why so many people were doing that? Never used it in the past. Seems a bit convoluted to me
Well if anyone has had any luck with creating their own operators and having it run as a button would be keen to see your script
_________________
....interesting....
Posted: Mon Mar 19, 2012 8:20 am
Yes, you have to register your operators. You want to see some sample code that works? Have a lookt at this:
https://github.com/ldo/gimp_palettes_for_blender.
Posted: Mon Mar 19, 2012 8:26 am
If you want a button example try this one:
https://github.com/ldo/treadtiler.
Posted: Mon Mar 19, 2012 8:51 am
thanks peeps! mustv typed something wrong i tried again with register and it worked. Also had to have the operator sub category as well
_________________
....interesting....
