Previous Thread  Next Thread
chat icon was going so well...
Wyatt
Posted: Mon Mar 26, 2012 11:40 pm
Very first time back in Linux after years, so any number of things may be going on here. Still, it never hurts to ask...
Running Ubuntu 11.10 on a 64-bit laptop, installed using wubi. Plenty of HDD space available. Not seeing any odd behavior indicative of memory issues, etc.
Followed the instructions here and everything went smoothly until 85% of the way through the very first build, when I get the following...
[ 85%] Building CXX object extern/bullet2/CMakeFiles/extern_bullet.dir/src/LinearMath/btGeometryUtil.cpp.o
[ 85%] Building CXX object extern/bullet2/CMakeFiles/extern_bullet.dir/src/LinearMath/btQuickprof.cpp.o
[ 85%] Building CXX object extern/bullet2/CMakeFiles/extern_bullet.dir/src/LinearMath/btSerializer.cpp.o
Linking CXX static library ../../lib/libextern_bullet.a
c++: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.6/README.Bugs> for instructions.
make[3]: *** [extern/libmv/CMakeFiles/extern_libmv.dir/libmv/multiview/euclidean_resection.cc.o] Error 4
make[2]: *** [extern/libmv/CMakeFiles/extern_libmv.dir/all] Error 2
make[2]: *** Waiting for unfinished jobs....
[ 85%] Built target extern_bullet
make[1]: *** [all] Error 2
make: *** [all] Error 2
Full make log is here. Any suggestions appreciated.
cheers,
w
ldo
Posted: Wed Mar 28, 2012 8:17 am
I have been able to build Blender just fine using GCC 4.6.3.
stiv
Posted: Wed Mar 28, 2012 5:39 pm
Usual fix for compiler errors (NOT COMPILATION ERRORS!) is to install either a new or an older version of the compiler.
Jump to:
