Previous Thread  Next Thread
chat icon Import Images as Plane - Need help with PNG File
themaddis
Posted: Sat May 26, 2012 11:23 pm
Hi, I am very new to blender. I have spent all day getting my head around it.
I am trying to import a png but every time a do this, however much i try, theres always white in the area that should be transparent.
When i click on 'Solid' in the viewport shading, the image looks right,:
But when i go to render / view in texture mode, i get this:
I have looked at many videos but all say different things. Can someone please help?
Thanks in advance Very Happy
Maddis[/img]
themaddis
Posted: Tue May 29, 2012 2:30 pm
Is this the best place to post for support? if not where a should i go?
Thanks in advance
stiv
Posted: Tue May 29, 2012 5:30 pm
The best place to go for questions about *using* blender are the forums at blenderartists.org . Discussions here are more focused on Blender development.
themaddis
Posted: Tue May 29, 2012 5:31 pm
Ok thanks mate Smile
ldo
Posted: Sat Jun 02, 2012 10:43 am
Can be done. You need to set up a number of things:
* Under the “Image Sampling” panel in the textures tab, make sure “Use” is checked under “Alpha” (I think this is the default).
* Under the “Influence” panel in the textures tab, make sure you have both colour and alpha checked in the “Diffuse” settings.
* Make sure “Transparency” is checked under the materials tab. Specify “Z-transparency”, and turn the Alpha slider all the way down to zero (if you want the fully-transparent parts of the PNG to be completely invisible) or some small value (if you want them to be translucent instead).
That should do it.
Jump to:
