when using I and locrot to change a position, all the previously inserted keyframe are changed ; I want only the change on the current selected keyframe : what should I do ?
(I'am always obliged to modify all the keyframes !)
Are you moving the time line slider to a new frame each time? If not you are overwriting existing keyframes for that frame.
you gotta insert a keyframe for the 1st frame to store the initial positions and rotations!
then insert keyframes where ever you want, they are only inserted at the current frame
_________________
I found a way to avoid this pb : I initialize all the keyframes to a first position and I change them all successivly according to my animation wishes.
Thanks for the replies.
