Previous Thread  Next Thread
chat icon Multiple Lamps and Keyframes
liamwilt
Posted: Tue Jun 12, 2012 10:08 pm
How does one select multiple lamps and manipulate their energies simultaneously over the course of several keyframes?
For instance, I have 10 lamps and 10 Key Frames. At key frame 1, I would like the energy of each lamp to be set to 0. At key frame 10, I would like the energy of each lamp to be set to 10. In between, I would like the lamps to increase in energy simultaneously as well.
So, I know I can go through and select them individually to have this occur, but, how might I select all lamps at once and alter their energies at the same time. I already attempted the "select all lamps" option, but, changing the energy only changed the energy of the initial lamp selected.
Please help if you can! Many thanks in advance!
_________________
Thank you.
CoDEmanX
Posted: Wed Jun 13, 2012 10:53 am
the properties editor on the right lets you edit properties of the active object. There doesn't seem to be a group editor yet...
But if you inserted a keyframe for lamp energy for each lamp, you can then go to Animation screen, select the lamp channels and duplicate the initial keyframes and move them around as a group (left-right: time, top-bottom: energy).
_________________
liamwilt
Posted: Wed Jun 13, 2012 6:36 pm
wonderful! thank you!
_________________
Thank you.
Jump to:
