Cycles with CPU+GPU
cautbur
Cycles with CPU+GPU
Postby cautbur » Sat Jun 16, 2012 1:28 pm
I am newbie and i don know if it is posiible. I dont know if this is the correct site where i have to suggets it.
I think cycles is a good render but i do not have a good graphic card and cuda is slow. So i have to use cpu. But i can fix the number of treads (i think this is the number of cpu treads that i have, 4 for a quadcore).
Windows 7 have an option to select wich cpus you can use in an application. It is useful when an application eats a lot of cpu, in this case the pc slow down and if imposiible to work, but if you free a cpu the system work well.
If i have a good graphic card, all cpus are free to compute the render and i think that i need only one cpu or two to move de application, and could be useful that i can add a number of cpu to the work of rendering with cuda. So i could render with all my cuda cores and for example two of my cpu, letting 2 treads for my systema and applications. It could improve the power on render.
It could be a future option to use cycles with gpu, cycles with cpu or cycles with gpu and cpu.
I don'y know if it is now implementd so excuse me if is implemented and tell me how to configure my system to do it.
abhinav
Postby abhinav » Mon Aug 20, 2012 11:32 pm
Hey i had this idea a few months ago and i thought the same, not for blender but for all renderers. But then i found a renderer ( arion) that does the job. At present rendering is done in cycles on gpu with cuda kernel so the compiled code cant be run on cpu i guess.
Return to “Coding Blender”
