Building Environment Simulation
spgun
Postby spgun » Sun Mar 18, 2012 6:34 am
Hi,I want to know whether it is possible to get the 3D view of a building when we enter the 2D plan of a building? May be a .CAD (AutoCAD File )
Please respond.
Thanks in advance
spgun
Re: Building Environment Simulation
Postby spgun » Fri Mar 23, 2012 6:11 am
Any ideas....??
BUMP
ldo
Postby ldo » Fri Mar 23, 2012 10:10 pm
Select the objects in your plan. Press E to extrude, Z to constrain to the Z axis. Make as tall as you want.
Simples!
spgun
Postby spgun » Sat Jun 16, 2012 12:42 am
ldo wrote:Select the objects in your plan. Press E to extrude, Z to constrain to the Z axis. Make as tall as you want.
Simples!
Thanks sir.
I will try on this.
Return to “Academic & Research”
