STL batch export (each object as separate file)
CoDEmanX
Postby CoDEmanX » Tue Jul 03, 2012 2:16 pm
i dunno where the original post has gone, where someone asked about batch stl export. He was having problems with the call
bpy.ops.export_mesh.stl(str)
filepath is not a positional argument
you need to pass it like
bpy.ops.export_mesh.stl(filepath=str)
and if you want to export all selected object, each into a separate file, you gotta use different code...
e.g.
Code: Select all
import bpy
# Keep a copy of user selection
sel_obs = bpy.context.selected_objects[:]
for ob in sel_obs:
    # Skip non-mesh objects
    if ob.type != 'MESH':
        continue
    # Clear selection
    bpy.ops.object.select_all(action="DESELECT")
    # Select single object
    ob.select = True
    # Export single object to STL
    bpy.ops.export_mesh.stl(filepath="D:\\temp\\batch_" + ob.name + ".stl")
# Restore user selection
for ob in sel_obs:
    ob.select = True
bpy.context.scene.objects.active = ob
Return to “Python”
