NLA.NewAction.setActive() overwrites Animations
Postby sabooakhter » Sun Jul 08, 2012 8:11 am
Hi there,
I'm using blender 2.49b to import multiple animation files that are in a different file format. I found a script to import these animations but it constantly writes over my previous animation. Any help would be awesome, thanks.
Here's the excerpt of code I believe is giving the problem:
Code: Select all
action_name = Blender.sys.basename(
action_name = action_name[0:action_name.find('.')]
action = Blender.Armature.NLA.NewAction(action_name)
for x in xrange(mesh_count):
     read_mesh_transformations(file_object, version, armature_object)
def ani_read_mesh_transformations(file_object, version, armature_object):
    key_frames = {}
    armature_pose = armature_object.getPose()
    armature_pose_bones = armature_pose.bones
    mesh_name =
    mesh_name = mesh_name[0:mesh_name.find('\0')]
    mesh_name = elu_to_blender_name(mesh_name)
    print "transform %s start 0x%x" % (mesh_name, file_object.tell() - 44)
    pm = struct.unpack('<16f',
    pose_matrix = Blender.Mathutils.Matrix([pm[0], pm[2], pm[1], pm[3]], \
                                           [pm[8], pm[10], pm[9], pm[11]], \
                                           [pm[4], pm[6], pm[5], pm[7]], \
                                           [pm[12], pm[14], pm[13], pm[15]])
    translation_count = struct.unpack('<I',[0]
#    print "translation count %d" % translation_count
    for x in xrange(translation_count):
        tx, ty, tz = struct.unpack('<3f',
        translation = Blender.Mathutils.Vector(tx, tz, ty)
        key_frame_second = int(struct.unpack('<I',[0] / 60)
        translation_matrix = Blender.Mathutils.TranslationMatrix(translation)
        key_frames[key_frame_second] = translation_matrix
    rotation_count = struct.unpack('<I',[0]
#    print "rotation count %d" % rotation_count
    for x in xrange(rotation_count):
        rotation_matrix = Blender.Mathutils.Matrix()
        rx, ry, rz, rw = struct.unpack('<4f',
        if version >= 0x1003:
            rotation = Blender.Mathutils.Quaternion(-rw, rx, rz, ry)
            rotation_matrix *= rotation.toMatrix().resize4x4()
            rotation = Blender.Mathutils.Quaternion([rx, rz, ry], math.degrees(-rw))
        if key_frame_second in key_frames:
            key_frames[key_frame_second] = rotation_matrix * key_frames[key_frame_second]
            parent_inverse_pose_matrix = Blender.Mathutils.Matrix()
            if mesh_name in armature_pose_bones.keys():
                if armature_pose_bones[mesh_name].parent is not None:
                    parent_inverse_pose_matrix *= armature_pose_bones[mesh_name].parent.poseMatrix.copy()
            key_frames[key_frame_second] = rotation_matrix * Blender.Mathutils.TranslationMatrix((pose_matrix * parent_inverse_pose_matrix).translationPart())
        if len(key_frames) > 0:
            for key_frame_second, key_frame_transformation in key_frames.iteritems():
                    key_frame_transformation *= armature_pose_bones[mesh_name].parent.poseMatrix.copy()
                armature_pose_bones[mesh_name].poseMatrix = key_frame_transformation
                armature_pose_bones[mesh_name].insertKey(armature_object, key_frame_second + 1)
            armature_pose_bones[mesh_name].poseMatrix = pose_matrix
            armature_pose_bones[mesh_name].insertKey(armature_object, 1)
Return to “Coding Blender”
