Batch object rename in 2.63
dom107
Postby dom107 » Mon Aug 13, 2012 11:09 pm
Hello,
Do you know a working script to rename batch of objects in Blender 2.63?
I unsuccessfully tested object_batch_rename_datablocks.py and object_multi_rename.py.
Thanks for your help.
CoDEmanX
Postby CoDEmanX » Thu Aug 16, 2012 6:25 pm
Batch Rename Datablocks script seems to work fine:
http://wiki.blender.org/index.php/Exten ... Datablocks
What it doesn't is renaming multi-user datablocks
dom107
Postby dom107 » Thu Aug 16, 2012 7:55 pm
Actually I didn't understood the interface of object_batch_rename_datablocks.py. I was expecting a field for the string to be replaced.
So I rewrote object_multi_rename.py extending the functionalities :D
Code: Select all
# ##### BEGIN GPL LICENSE BLOCK #####
#  This program is free software; you can redistribute it and/or
#  modify it under the terms of the GNU General Public License
#  as published by the Free Software Foundation; either version 2
#  of the License, or (at your option) any later version.
#  This program is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#  GNU General Public License for more details.
#  You should have received a copy of the GNU General Public License
#  along with this program; if not, write to the Free Software Foundation,
#  Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
# ##### END GPL LICENSE BLOCK #####
bl_info = {
    "name": "MultiRename_dom",
    "author": "dom107",
    "version": (1,0),
    "blender": (2, 6, 3),
    "location": "View3D > Toolbar",
    "description": "Provides a find & replace function for renaming multiple objects and bones",
    "warning": "",
    "wiki_url": "",
    "tracker_url": "",
    "category": "Object"}
# Adapted from a script by Maximilian Eham
# as found at http://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/Object/Object_Multi_Rename on 2012/08/16
import re, fnmatch
import bpy
from bpy.props import *
from bpy.app.handlers import persistent
def draw_rename_panel(self, context):
    layout = self.layout
    sce = context.scene
    mode = context.mode
    col = layout.column(align=True)
    col.operator("object.multi_object_rename_dom")
    layout.prop(sce, "erase_string_panel")
    layout.prop(sce, "replace_panel")
    layout.prop(sce, "trim_panel_start")
    layout.prop(sce, "trim_panel_end")
    layout.prop(sce, "prefix_panel")
    layout.prop(sce, "suffix_panel")
    layout.prop(sce, "rename_selected_panel")
    if context.mode == 'OBJECT':
        layout.prop(sce, "rename_object_data_panel")
    col.operator("object.multi_object_rename_dom_reset")
class OBJECT_RENAME_tools_multiobjectrename(bpy.types.Panel):
    bl_space_type = 'VIEW_3D'
    bl_region_type = 'TOOLS'
    bl_context = "objectmode"
    bl_label = "Objects Renamer"
    bl_options = {'DEFAULT_CLOSED'}
    @classmethod
    def poll(cls, context):
        return (context.object is not None)
    def draw_header(self, context):
    def draw(self, context):
class OBJECT_RENAME_tools_multibonerename(bpy.types.Panel):
    bl_context = "armature_edit"
    @classmethod
class OBJECT_RENAME_tools_multiposebonerename(bpy.types.Panel):
    bl_context = "posemode"
    @classmethod
def doSingleObjectRename(object, eraseString, replacementString, trimStart, trimEnd, newPrefix, newSuffix, rename_object_data, mode):
    temp = object.name[trimStart:]
    if trimEnd > 0:
        temp = temp[:-trimEnd]
    temp = re.sub(eraseString, replacementString, temp)
    temp = newPrefix + temp + newSuffix
    object.name = temp[:]
    if mode == 'OBJECT':
        if object.data:
            if rename_object_data:
                object.data.name = object.name
def doMultiObjectRename(self, context, eraseString, replacementString, trimStart, trimEnd, newPrefix, newSuffix, rename_selected, rename_object_data):
    eraseString = fnmatch.translate(eraseString)[:-7] #convert shell wildcards to regular expression and trunc the last 7 chars (why do they get generated by fnmatch???)
    num_objects = 0
    if context.mode == 'EDIT_ARMATURE':
        if rename_selected:
            bones_list = context.selected_bones
        else:
            bones_list = context.object.data.bones
        for bone in bones_list:
            doSingleObjectRename(bone, eraseString, replacementString, trimStart, trimEnd, newPrefix, newSuffix, rename_object_data, context.mode)
            num_objects += 1
    elif context.mode == 'OBJECT':
        if rename_selected:
            objects_list = context.selected_objects
        else:
            objects_list = context.scene.objects
        for obj in objects_list:
            doSingleObjectRename(obj, eraseString, replacementString, trimStart, trimEnd, newPrefix, newSuffix, rename_object_data, context.mode)
            num_objects += 1
    elif context.mode == 'POSE':
        if rename_selected:
            bones_list = context.selected_pose_bones
        else:
            bones_list = context.object.pose.bones
            num_objects += 1
    if num_objects == 0:
        self.report({'INFO'}, "No object processed")
    else:
        self.report({'INFO'}, str(num_objects) + " objects processed")
class MultiObjectRename(bpy.types.Operator):
    '''Find & Replace-functionality for names'''
    bl_idname = "object.multi_object_rename_dom"
    bl_label = "Rename"
    bl_description = "Find & Replace functionality for object and bone names"
    bl_options = {'REGISTER', 'UNDO'}
    def execute(self, context):
        sce = context.scene
        something_todo = True
        if context.mode == 'OBJECT' and sce.rename_object_data_panel:
        else:
            if sce.erase_string_panel == "" and sce.replace_panel == "" and \
                sce.trim_panel_start == 0 and sce.trim_panel_end == 0 and \
                sce.prefix_panel == "" and sce.suffix_panel == "":
                    something_todo = False
                    self.report({'INFO'}, "Nothing to process")
        if something_todo:
            doMultiObjectRename(self, context, sce.erase_string_panel, sce.replace_panel,
                sce.trim_panel_start, sce.trim_panel_end,
                sce.prefix_panel, sce.suffix_panel, sce.rename_selected_panel, sce.rename_object_data_panel)
        return {'FINISHED'}
class OBJECT_RENAME_reset_button(bpy.types.Operator):
    bl_label = "Reset fields"
    bl_idname = "object.multi_object_rename_dom_reset"
    bl_description = "Reset input fields"
    bl_options = {'REGISTER'}
        sce = context.scene
        sce.erase_string_panel = ""
        sce.replace_panel = ""
        sce.trim_panel_start = 0
        sce.trim_panel_end = 0
        sce.prefix_panel = ""
        sce.suffix_panel = ""
        return {'FINISHED'}
# http://www.blender.org/documentation/blender_python_api_2_60_6/bpy.props.html
def register():
    bpy.utils.register_module(__name__)
    bpy.types.Scene.erase_string_panel = bpy.props.StringProperty(name="Find String",
        description = "The string to look for in the object names (shell wildcards supported)",
    bpy.types.Scene.replace_panel = bpy.props.StringProperty(name = "Replace with",
        description = "The replacement for the string given above",
    bpy.types.Scene.trim_panel_start = bpy.props.IntProperty(name="Trim Start:",
        description = "Erases the specified number of characters from the beginning of the object names",
        min = 0,
        max = 50,
        default = 0,
    bpy.types.Scene.trim_panel_end = bpy.props.IntProperty(name="Trim End:",
        description = "Erases the specified number of characters from the end of the object names",
        min = 0,
        max = 50,
        default = 0,
    bpy.types.Scene.prefix_panel = bpy.props.StringProperty(name = "Prefix with",
        description = "Adds the specified characters to the beginning of the object names",
    bpy.types.Scene.suffix_panel = bpy.props.StringProperty(name = "Suffix with",
        description = "Adds the specified characters to the end of the object names",
    bpy.types.Scene.rename_selected_panel = bpy.props.BoolProperty(
        name="Selected objects",
        description="If checked, renaming will only affect selected objects",
        default=0)
    bpy.types.Scene.rename_object_data_panel = bpy.props.BoolProperty(
        name="Object data",
        description="If checked in object mode, the object data gets the object name whether a object name change is done or not",
        default=0)
    pass
def unregister():
    bpy.utils.unregister_module(__name__)
    # Remove properties
    del bpy.types.Scene.erase_string_panel
    del bpy.types.Scene.replace_panel
    del bpy.types.Scene.trim_panel_start
    del bpy.types.Scene.trim_panel_end
    del bpy.types.Scene.prefix_panel
    del bpy.types.Scene.suffix_panel
    del bpy.types.Scene.rename_selected_panel
    del bpy.types.Scene.rename_object_data_panel
    pass
if __name__ == '__main__':
    register()
if __name__ == "__main__":
    register()
proxe
Postby proxe » Fri Feb 01, 2013 3:57 pm
I made this add-on over the last few weeks:
http://blenderartists.org/forum/showthr ... tch-Naming
It should have everything you need short of naming materials and textures which I plan on implementing shortly.
dom107
Postby dom107 » Fri Feb 01, 2013 4:06 pm
proxe wrote:I made this add-on over the last few weeks:
Thanks!
Return to “Coding Blender”
