Predictable Noise Texture
brandon
Postby brandon » Sun Nov 30, 2003 6:42 pm
I am not sure if I am doing something wrong, but whenever I use the noise texture in an animation, it renders as a new pattern for each frame.
Is there any way to decouple the noise function from time?
As an aside, I've tried to mimic this using an image, but my results never look nearly as good as the stills I can produce with the niose function.
z3r0_d
Postby z3r0_d » Sun Nov 30, 2003 6:48 pm
correct, the noise texture is different every frame
try using the clouds texture and scaling it down a lot
z3r0_d
Postby z3r0_d » Sun Nov 30, 2003 6:49 pm
_________________ EDIT://blah
yes I did post twice, it didn't claim it worked though
General Error:
"Failed sending email"
(bah)
SirDude
Postby SirDude » Mon Dec 01, 2003 5:29 pm
There are some other plugins you can use, for example
fixnoise. ;)
http://www-users.cs.umn.edu/~mein/blend ... xture.html
brandon
Postby brandon » Tue Dec 02, 2003 2:23 am
Thank. Being new with Blender I wasn't sure if I was doing something wrong.
Also, thanks for the link to the plugins. One of them comes pretty close to what I need.
Return to “Rendering”
Users browsing this forum: Yahoo [Bot] and 1 guest
