Posted: Fri Aug 24, 2012 7:34 am
Hi.
I don't understand how to connect Blender + OpenGL + Python.
I have create a cube 3d in blender.
Now i want to use this cube in my python script in which use opegl to move the cube.
IN particular I use the OpenGL functions:
- glRotatef
- glTranslatef
- glScalef
Can i make this???
Help please!
Posted: Fri Aug 24, 2012 10:10 pm
what's the target environment?
do you want to animate the cube inside of blender, rendering it later to a video?
do you have an OpenGL application (like written in C++ or C#) and want to import models from blender?
_________________
Posted: Fri Aug 31, 2012 10:41 am
HI!
I want animate the cube in my python script (in which use openGL library).
My application is in Python and i want import cube in this my script..... when i want to rotate the cube.
My problem is: can i use blender cube in python script and animate this cube normally with OpenGL? How?
Thanks!
Posted: Fri Aug 31, 2012 9:49 pm
if i got you right, you coded a python application which draws 3d content in a window using opengl.
i would export a cube / models to a common format like OBJ and write an importer for mesh geometry for your app (i bet there are examples on the web)
you could then use any opengl features i guess
_________________
