Learning blender python - GUI
Postby radubolovan » Thu Aug 30, 2012 11:22 am
I just started to learn GUI blender python and go through tutorials and API Doc. Long story short I have this script which I put it in blender_scripts_root/startup:
Code: Select all
import bpy
class CustomDrawOperator(bpy.types.Operator):
   bl_idname = "object.custom_draw"
   bl_label = "Simple Modal Operator"
   filepath = bpy.props.StringProperty(subtype="FILE_PATH")
   def execute(self, context):
      print("Test", self)
      return {'FINISHED'}
      return {'RUNNING_MODAL'}
class HelloWorldPanel(bpy.types.Panel):
   bl_label      = "Hello World Panel"
   bl_idname      = "OBJECT_PT_hello"
   bl_space_type   = "PROPERTIES"
   bl_region_type   = "WINDOW"
   bl_context      = "object"
   my_test_bool   = bpy.props.BoolProperty(name="my_test_bool", description="a bool property", default=False, options={'ANIMATABLE'}, subtype='NONE', update=None)
   def draw(self, context):
      layout = self.layout
      obj = context.object
      row = layout.row()
      row.label(text="Hello world!", icon='WORLD_DATA')
      row = layout.row()
      row.label(text="Active object is: " + obj.name)
      row = layout.row()
      row.prop(obj, "name")
      row = layout.row()
      row.prop(self, "bl_context")
      row = layout.row()
      row.prop(self, "my_test_bool")
      row = layout.row()
def register():
def unregister():
if __name__ == "__main__":
Everything is fine, except this:
Code: Select all
I can't see it. Can someone tell me what I did wrong?
OBS1 - in the console is this info: "property not found: OBJECT_PT_hello.my_test_bool" <- very strange
OBS2 - I have Blender 2.6.2 running on Windows7.
Thanks in advance for any info about my not working code code.
Return to “Python”
