Previous Thread  Next Thread
chat icon Anchor objects to a surface
roldy
Posted: Sat Sep 01, 2012 7:27 am
Is there a way to anchor multiple objects to a surface? For example, I want to make a word out of rectangular blocks (long side vertical). I then want to "anchor" all these blocks to a surface which is in the shape of radial propagating wave (like when you see after a water drop hits still water). The wave will be invisible, thus leaving only the word made up of blocks where the blocks are all shifted vertically because of the radial wave. I'm a beginner with using Blender and would like to learn as much as a can. Thank you for any help.
CoDEmanX
Posted: Sun Sep 02, 2012 1:19 pm
manual way: turn on snapping and set it surve i guess (if you "wave" is a mesh)
but you can certainly use modifiers, maybe even Wave together with Array.
you can also align objects to a curve, if i'm not mistaken using Curve modifier.
_________________
Jump to:
