Vector help!
jerpace
Vector help!
Postby jerpace » Wed Sep 05, 2012 11:50 am
I am a bit of a newbee when it comes to Blender and I was curious about some thing. When i am working with typography i would like to be able to export the artwork as a vector (eps, svg etc). The thing is I have looked around and found the VRM addon, I installed but it doesn't seem to be working. In fact it is not even visible as one of the options to render.
I would like to be able to export it as a vector so that i can combine it with the rest of the artwork that i will be doing in Adobe Illustrator.
I am currently running Blender v2.60 on OSX.
I look forward to hearing from you!
Thanks!
Jeremy
ZackatSumoFilms
Re: Vector help!
Postby ZackatSumoFilms » Sun Sep 09, 2012 12:19 am
jerpace wrote:Hi,
I'm wondering if you installed it correctly. If you downloaded it and added it to your scripts>addons folder then it should show up in your User Prefs Addons Menu under Import-Export. But, you may need to install it manually using the Install Add-on button and point the computer to the script. You probably already did this, but I'm just making sure and letting you know somebody is actually looking at the post. :D
Zack Miller
www.sumofilms.com
Return to “Rendering”
Users browsing this forum: No registered users and 3 guests
