Compile terminating
mikevan
Compile terminating
Postby mikevan » Thu Sep 06, 2012 1:10 am
I've been compiling svn almost daily for several weeks with no issues. Today, it's choking on the CUDA:
Code: Select all
"/opt/cuda/bin/nvcc" -arch=sm_21 -m64 --cubin --ptxas-options="-v" --maxrregcount=24 --opencc-options -OPT:Olimit=0 -DCCL_NAMESPACE_BEGIN= -DCCL_NAMESPACE_END= -DNVCC -I "intern/cycles/kernel/../util" -I "intern/cycles/kernel/../svm" "intern/cycles/kernel/kernel.cu" -o "/home/mikev/Documents/CreativeTools/Blender/Blender-SVN/build/linux/intern/cycles/kernel/kernel_sm_21.cubin"
nvcc warning : Option '--opencc-options (-Xopencc)' is obsolete and ignored, when targeting compute_20, sm_20, or higher
In file included from intern/cycles/kernel/kernel_types.h:25:0,
                 from intern/cycles/kernel/kernel.cu:23:
intern/cycles/kernel/../util/util_param.h:25:35: fatal error: OpenImageIO/paramlist.h: No such file or directory
compilation terminated.
Here's my user-config.py if that helps any:
Code: Select all
WITH_BF_OIIO = True
WITH_BF_BOOST = True
WITH_BF_OPENMP = True
WITH_BF_FFTW3 = True
WITH_BF_GAMEENGINE = True
WITH_BF_OPENEXR = True
WITH_BF_FFMPEG = True
WITH_BF_OPENAL = True
WITH_BF_JACK = True
WITH_BF_SNDFILE = True
WITH_BF_SDL = True
WITH_BF_DDS = True
WITH_BF_BULLET = True
WITH_BF_FREETYPE = True
WITH_BF_COLLADA = True
BF_OPENCOLLADA_INC = '/home/mikev/Documents/CreativeTools/Blender/OpenCollada-SVN/opencollada'
BF_OPENCOLLADA_LIBPATH = '/home/mikev/Documents/CreativeTools/Blender/OpenCollada-SVN/opencollada/lib'
BF_PCRE_LIBPATH = '/home/mikev/Documents/CreativeTools/Blender/OpenCollada-SVN/opencollada/Externals'
BF_EXPAT_LIBPATH = '/home/mikev/Documents/CreativeTools/Blender/OpenCollada-SVN/opencollada/Externals'
BF_OPENCOLLADA_LIB = 'libOpenCOLLADAStreamWriter-static.a ' + \
    'libOpenCOLLADASaxFrameworkLoader-static.a ' + \
    'libOpenCOLLADAFramework-static.a ' + \
    'libOpenCOLLADABaseUtils-static.a ' + \
    'libGeneratedSaxParser-static.a ' + \
    'libUTF-static.a '+ \
    'libMathMLSolver-static.a ' + \
    'pcre ' + \
    'libbuffer-static.a ' + \
    'libftoa-static.a'
WITH_BF_PLAYER = True
WITH_BF_3DMOUSE = True
WITH_BF_RAYOPTIMIZATION = True
WITH_BF_CYCLES_CUDA_BINARIES = True
BF_CYCLES_CUDA_NVCC = '/opt/cuda/bin/nvcc'
BF_CYCLES_CUDA_BINARIES_ARCH = ['sm_13', 'sm_20', 'sm_21']
BF_DEBUG = False
BF_NUMJOBS = 1
I'll try and update svn later this evening and see if I just caught things in the middle of check-ins.
mikevan
Postby mikevan » Thu Sep 06, 2012 1:16 am
Compiles fine with CUDA turned off. Of course, CUDA is a must for me.
stiv
Postby stiv » Thu Sep 06, 2012 6:16 pm
Should be fixed now. One of the hazards of dealing with the development version.
Return to “Coding Blender”
Users browsing this forum: No registered users and 3 guests
