YABN - Yet Another Build Newbie
Postby Kurs » Thu Sep 06, 2012 4:11 am
Sorry if this has been asked and answered before, but I haven't found it yet. Still looking through past messages, but there's a lot out there.
I've finally got Blender to compile, but when I run the blender.exe from the 'install' directory, it get a large, blank, grey screen and then a popup about "Blender has stopped working". So obviously, I've missed something.
I'm working on a 64-bit, Windows 7 PC.
I'm trying the 32-bit build using SCONS and MinGW. I've got it to compile. I don't think there are any compile errors, but it's a long compile and some of it scrolls by too fast. (Is there an easy way to log compile messages??)
Do I have to go the 64-bit route, since I'm on a 64-bit machine? I can run both 32 & 64 bit downloaded blenders.
I stayed away from the 64-bit build once I started to read about it being 'experimental'.
With out any other error message, I'm not sure what to try.
Postby stiv » Thu Sep 06, 2012 6:13 pm
The usual cause of missing menus and such is running blender from the build directory instead of the install dir.
Won't run from install directory
Postby Kurs » Thu Sep 06, 2012 8:18 pm
I'm running from the install directory. If it were something missing, I might come up with a guess of where/what to look at. But it just won't start, even with command line debugging on, there's no output.
That path command is in my compile batch script. Just checking if it made any difference in running Blender or not. No difference. I get the same popup about it stopped working. No output to the DOS window I start it from. No separate system console opens.
Same thing, just that popup, running:
blender.exe --help
or blender.exe
I can run both 64 & 32-bit Blender 2.63a downloads from http://www.blender.org/download/get-blender/
The compile is completing and creating an executable each time. I don't see any error messages on re-compiles. I'm going run the:
python scons\scons.py BF_TOOLSET=mingw clean
and let the compiler rip thru all of the code again. Not that I'm sure what to look for. It's so long and has so many warnings (is that normal??). I hate to ask about making it more verbose, but are there compiler, debug switches to turn on that might give me a clue?
Postby Tehrasha » Fri Sep 07, 2012 4:05 am
I do not think you will have much luck compiling Blender 2.63 with Python 2.6.
Spacemice Wiki -- Input devices for a 3D world.
Spacemice / Blender Compatibility
Postby Kurs » Fri Sep 07, 2012 5:03 am
It compiled with 32-bit Python 2.6.6
I've uninstalled 2.6.6 and have installed 32-bit Python 2.7.3 and the pywin32 that goes with it. After cleaning the directories and doing a svn update:
set PATH=C:\Python27;C:\MinGW\bin;C:\MinGW\lib;%PATH%
cd C:\BlenderSVN\blender\
Compiles like before. Crashes like before. Maybe 'crash' is giving it too much credit. Little seems to ever get started.
Just read something about "If you have Quicktime installed, Blender attempts to link with it on startup." Is there anything else like that at startup? Is there a way to switch that off with the compiler config file?
Postby Kurs » Fri Sep 07, 2012 6:08 am
Frak!!! :oops:
Here I thought I might contribute to the debugging effort someday and I can't even get a compile of this thing to run.....
Still don't know where to look, but at least it's a different popup now.
Using 32-bit Python 2.7.3, win32-mingw, and scons.
Added a user-config.py:
Code: Select all
BF_BUILDDIR = 'C:\\BlenderSVN\\build\\win32-mingw'
BF_INSTALLDIR = 'C:\\BlenderSVN\\install\\win32-mingw'
Compiling with:
Code: Select all
Build looks normal (I guess??):
Code: Select all
C:\BlenderSVN>time /t
11:23 PM
C:\BlenderSVN\blender>python scons\scons.py BF_TOOLSET=mingw
scons: Reading SConscript files ...
Command-line arguments
        BF_TOOLSET = mingw
Command-line targets
        No targets given, using default
Using mingw
Using config file: build_files\scons\config\win32-mingw-config.py
Using user-config file: user-config.py
Build with parallel jobs: 6
Build with debug symbols: True
Generating: 'COM_OpenCLKernels.cl.h'
Generating: 'startup.blend.c'
Generating: 'preview.blend.c'
Generating: 'gpu_shader_material.glsl.c'
~9900 lines later
C:\BlenderSVN\lib\mingw32\boost\include/boost/random/detail/integer_log2.hpp:71:35: warning: always_inline function might not be inlinable [-Wattributes]
Linking library ==> 'libextern_carve.a'
Linking library ==> 'libextern_ceres.a'
Linking program ==> 'blender.exe'
Linking program ==> 'blenderplayer.exe'
Install file: "C:\BlenderSVN\build\win32-mingw\bin\blenderplayer.exe" as "C:\BlenderSVN\install\win32-mingw\blenderplayer.exe"
Trying to remove existing py bundle.
Unpacking '../lib/mingw32/release/python32_d.tar.gz' to 'C:\BlenderSVN\install\win32-mingw\2.63\python\lib'
Install file: "C:\BlenderSVN\build\win32-mingw\bin\blender.exe" as "C:\BlenderSVN\install\win32-mingw\blender.exe"
scons: done building targets.
C:\BlenderSVN\blender>time /t
11:32 PM
Postby Kurs » Sat Sep 08, 2012 5:25 am
Well, I didn't want to go the Microsoft route, but what the heck, I've got a 32-bit compile with scons and Visual C++ 2008 Express working and the executable even runs!! :D
Mingw/scons still baffles me. Event log seems to blame libstdc++-6.dll.
Code: Select all
Application Error 2012-09-07T15:14:28.000000000Z
Level: Error
- EventData
But honestly, I don't know what I'm looking at here.
Return to “Coding Blender”
