Exporting Animation as Wavefront (obj) - Wall Destruction
StickySteve
Postby StickySteve » Mon Sep 17, 2012 8:27 pm
Im trying to get an animation where my wall model destructs where an object has hit it ( boulder from catapult hitting wall):
i have failed to produce anything good in 'blender render' where i would set keyframes using the explode modifier and the particle system,
when i use the "blender game" physics with a ball hitting a wall i got much better results;
but i need to have the animation in frames to export the damage of the wall as wavefront (obj) files at different frames in the animation.
So my main question is, can I make my animation into frames with blender game physics, or do I have to manually animate each brick separately to achieve an animation with frames?
Any other ways of doing this?
thanks
Jedijds
Postby Jedijds » Mon Sep 17, 2012 8:40 pm
Try setting up your animation for blender game engine. Don’t forget to change to Blender Game Engine from Blender Render. Run the game and get the bugs out until you have it the way you want it. Then in the info bar at the top of the screen, click on the “game” button. In the dropdown menu there is a box next to “Record Animation,” check it. Now run the game engine. This should have recorded every thing that happened in the game to keyframes. Note that this process will record 60 frames a second, I don’t really know how to get it to record slower than that, so just play with the settings. Hope that helps. :)
۞◄█°‖‖‖‖‖█ʭʭ╬(░▒▓▓▒▒▒▒▒▒▒▒▒)
StickySteve
Postby StickySteve » Mon Sep 17, 2012 8:49 pm
Thankyou!!!! XD
Jedijds
Postby Jedijds » Mon Sep 17, 2012 9:09 pm
No problem. Just a suggestion, but YouTube has a lot of helpful tutorials. Just type “blender (a topic) tutorial” if it doesn’t show you exactly what you need you might still learn something that you could use later. :D
Return to “Animation”
