i want to remove the blur
bedmen
Postby bedmen » Mon Sep 17, 2012 5:55 pm
i got always when i load a low texturepack or 16x16 pixels it shows blur every where!!! does somone know how to disabel this blur! thank you!
example
http://www.youtube.com/watch?v=By9i_wN7SOA&list=UU06SLSDN0yaDZEH1QUNHySg&index=1&feature=plcp
Jedijds
Postby Jedijds » Thu Sep 20, 2012 3:53 pm
16 x16 is very small. The blur is probably caused by blender trying to stretch the image out enough for the camera to see it over the entire object. Try using a texture that’s a little larger if possible or tile it so that the one image does not need to be stretched as far.
Sorry if i wasn't much help
۞◄█°‖‖‖‖‖█ʭʭ╬(░▒▓▓▒▒▒▒▒▒▒▒▒)
bedmen
Postby bedmen » Thu Sep 20, 2012 4:46 pm
Jedijds wrote:16 x16 is very small. The blur is probably caused by blender trying to stretch the image out enough for the camera to see it over the entire object. Try using a texture that’s a little larger if possible or tile it so that the one image does not need to be stretched as far.
i found the awnser already finaly ;D but thanks. and the mc textures are 16x16 and i don't want to chance the defaults of minecraft :D
Jedijds
Postby Jedijds » Thu Sep 20, 2012 6:00 pm
Would you mind sharing your answer so others with the problem could fix it or is it so hard to explain?
bedmen
Postby bedmen » Fri Sep 21, 2012 5:28 pm
Jedijds wrote:Would you mind sharing your answer so others with the problem could fix it or is it so hard to explain?
ok
Return to “Documentation & Education”
