Previous Thread  Next Thread
chat icon Need Help! Unable to use Grab correctly.
Yumilong
Posted: Fri Oct 05, 2012 10:55 am
I select two vertices and press the "G". However, Blender create some new vertices instead of moving the selected ones. I feel very confused.
PS, I am in the edit mode and the grab tools works fine before.
MatejMo
Posted: Fri Oct 05, 2012 11:22 am
Yumilong wrote:
...the grab tools works fine before.
Did you mess with key settings?
_________________
matejmo.deviantart
Yumilong
Posted: Fri Oct 05, 2012 11:37 am
I think it must be some key i press incidently.
So, I save my project and create a new file using loading the factory setting.
Then, everything works fine. I can use grab tool property.
But as if i reload my project, select vertices and press "g", grab tools still unable to work in the right way.
Tehrasha
Posted: Fri Oct 05, 2012 5:48 pm
At some point you may have extruded the verticies but did not move them.
So when you selected them to move them, you only grabbed one pair.
'Remove Doubles' would have also fixed. it.
Jump to:
