stdout.readline() works in Python but not in Blender
heskn
Postby heskn » Sat Oct 06, 2012 10:00 am
import subprocess
NvTriStripPath = "C:/NvTriStripper-cli.exe"
vert_indices = [ 0, 1, 2, 1, 3, 2 ]
# Stripifying mesh
NvTriStrip = subprocess.Popen([NvTriStripPath],
stdin = subprocess.PIPE,
stdout = subprocess.PIPE)
for vi in vert_indices: NvTriStrip.stdin.write(str(vi).encode() + " ".encode())
NvTriStrip.stdin.write("-1\n".encode())
print("STEP 1")
mashit = NvTriStrip.stdout.readline()
print("STEP 2")
stripcount = int(mashit)
if stripcount < 1: raise Exception("NvTriStrip returned 0 strips. Aborting")
nativelist = []
striptype = int(NvTriStrip.stdout.readline())
nativelength = int(NvTriStrip.stdout.readline())
nativelist.extend(map(int, NvTriStrip.stdout.readline().split()))
print(nativelist)
the above script works perfectly in python. the output is:
Code: Select all
STEP 1
STEP 2
[0, 1, 2, 3]
but when i try to run it in blender if freezes the main window, and the last line in console window is:
Code: Select all
STEP_1
NvTriStripper-cli.exe is in the root of the disk C:\
please help...
CoDEmanX
Postby CoDEmanX » Sat Oct 06, 2012 8:34 pm
it's not intended to use a console beside Blender's interface...
but if you open Blender's console window, you should be able to use
os.read() and input()
sys.stdout.readline() gives me error:
io.UnsupportedOperation: not readable
stiv
Postby stiv » Sat Oct 06, 2012 9:57 pm
No idea what your exe is doing, but you might try putting in a flush after the write, just in case blender is still waiting on the I/O to finish.
heskn
Postby heskn » Wed Oct 10, 2012 11:30 am
thank you guys for your replies. thanks god the flush() thing managed the thing - now i can create triangle strips without rewriting old 2.49 scripts :)
Return to “Python”
