Posted: Sun Oct 07, 2012 4:52 pm
Im very lost now, added a mirror then copied the object and wanted to remove the mirror, but couldnt find the option, ended up with loads of windows all over my screen, finally managed to find out you can drag the small lines at the top right to merge the window with another window, then i clicked "view full 3d"(or something like that) and now i can see just the window that has the object within... my menu bar at the top has now vanished and all i can do is drag areas and have more windows????
would be nice to have a menu that has "windows" then you can tick and untick the windows you want open
how do i get my menu back? how do i show the window that allowed me to add a mirror?
Posted: Sun Oct 07, 2012 5:10 pm
ok, closed and opend my project and my menu is back...
Still have two unwanted windows open, just cant get rid of them, see below:
http://www.treendsolutions.co.uk/test/current.jpg
its the two on the right, as its the same as my main windows
also this screen:
http://www.treendsolutions.co.uk/test/current2.jpg
thats the window i want to have open... where is it?
thank you
Posted: Wed Oct 17, 2012 1:56 am
It sounds like it originally got set to full screen mode which can be toggled with ALT + F11 or from within the window menu.
The current view can be maximized with CTRL + up and CTRL + down as well.
The windows you referred to are the outliner and properties panels. They can be set by clicking the button in the lower left corner of each panel
Here is a link to a picture that explains more clearly
http://screencast.com/t/hhAsj8VK
I encourage you to visit
http://blenderartists.org/ for future support as many of us are more active there. I hope this helps.
