SpaceNavigator: Assign different behaviour
Fluxo
Postby Fluxo » Mon Oct 15, 2012 2:56 pm
Hi blender-experts,
I am coming from C4D and here and then I try out blender.
Since a few days I've got a spacenavigator by 3dconnexion. Installed drivers and it worked directly in C4D and blender.
Unfortunately, blender has somewhat of a bad mapping (from my perspective).
I would love to assign the rotate funrtionality to the sping cw/ccw, panning to left right. Is this possible with blender?
Otherwise I have to re-learn each time when I switch!
Thanks for a short hint!
Tehrasha
Re: SpaceNavigator: Assign different behaviour
Postby Tehrasha » Mon Oct 15, 2012 4:52 pm
Fluxo wrote:I would love to assign the rotate funrtionality to the sping cw/ccw, panning to left right. Is this possible with blender?
I was able to understand everything in your post, up to his point.
You will have to find a different way to describe the functionality you are looking for as the above makes no sense to me.
Fluxo
Postby Fluxo » Mon Oct 15, 2012 5:02 pm
Hi Tehrasha,
I'll try to explain more clearly:
Currentle when I tilt the device left / right I will rotate to the left / right of the currently selected object.
I want it to change so that when I use the rotate function to rotate clockwise or counter-clockwise resepectively I will rotate around the object.
And furthermore, when I tilt the device to left or right, I want it to pan my scene instead of rotating.
Is this more clearly?
Return to “Coding Blender”
