Importing .stl Objects in a Python Script
neanderslob
Postby neanderslob » Mon Oct 22, 2012 5:15 am
Hi all,
I'm very new to python scripting in blender, however I've run across an application where I need to do so. I'm trying to write a python script that imports a .stl file, does some other stuff (not important), and then exports it as an x3d file. I'd assume this would be very easy; this functionality exists under the gui File menu, however I can't figure out how to get it to work in a python script. My understanding is that the two functions in the file menu call python scripts of their own located in the scripts/addons/ directory. Any tips as to how I can make this happen?
Thanks in advance! :)
neanderslob
Postby neanderslob » Mon Oct 22, 2012 9:57 pm
Some nice fellow by the name of "Atom" gave me a tip over at blenderartists.org and it helped me clear the whole thing up. I'll post my findings below to help out other hapless noobs like me. I also ran into a general tool that would probably be helpful for anyone trying to write any python script in Blender.
So the code ended up looking like the following:
Code: Select all
bpy.ops.import_mesh.stl(filepath="/home/sam/KAPPA.stl", filter_glob="*.stl", files=[{"name":"KAPPA.stl", "name":"KAPPA.stl"}], directory="/home/sam/")
where /home/sam/ was my home directory. I was able to find this by running Blender in my terminal with debugging on (apparently a great little tool for trying to script something you know how to do in the GUI). For linux users, like myself, just pop open the terminal and enter
Code: Select all
blender -d
. Then preform whatever tasks you want to code and watch the terminal to see what text pops up. It's a bit like watching the "Info" window on scripting mode but it's a lot more explicit.
Cheers!
Return to “Python”
