Previous Thread  Next Thread
chat icon Having trouble installing a script
Sean67
Posted: Sat Nov 03, 2012 3:23 am
Hi everyone, Im a noob and I am not sure what to do. I understand how to install an add-on, but this add-on called the window generator I cant install.
When I click the download link to get the add-on it doesn't download it just fills a browser window with the python text. I am not sure what to do with it. I hope this makes sense. Thanks for any help.
Tehrasha
Posted: Sat Nov 03, 2012 8:00 am
If you mean this... http://blenderartists.org/forum/showthread.php?270422-AddOn-Window-Generator-2
In Browser...
Right-click link, Save link as.. (or however your browsers saves files)
In Blender...
Start with a blank empty project.
File --> User Preferences --> Addons Tab
Install Addon button at bottom of the window.
Navigate to wherever your browser saved the file...
select the file 'add_Window.py' , click 'Install Addon'
dont forget to activate the plugin by clicking the checkbox at the far right of the plugin named "Window Generator 2"
Click 'Save as default'
Now open your current project, or start a new one to use the addon...
_________________
Spacemice Wiki -- Input devices for a 3D world.
Spacemice / Blender Compatibility
Sean67
Posted: Sat Nov 03, 2012 3:55 pm
Thank You Tehrasha. I never knew this. I thought that would only save a link and just go back to the page. Now I can get some more addons I have wanted. Thanks once again.
Mikawa
Posted: Fri Dec 28, 2012 9:55 am
Hello
I'm a french Mac User (G5 PPC under 10.5.Cool and I've the same issue when trying to install new scripts. I tried many different ways, either by manually dragging the scripts into the right directory or by using the Install Addon button.
Here is what the terminal displays:
[MacDuHaut:~] Papa% /Users/Papa/Applications/blender-2.63/blender.app/Contents/MacOS/blender
ndof: 3Dx driver not found
2012-12-28 08:46:47.673 blender[260:807] *** _NSAutoreleaseNoPool(): Object 0x73a0750 of class NSCFArray autoreleased with no pool in place - just leaking
Stack: (0x975aadac 0x974d7e14 0x96b7156c 0x96c48730 0x96b81e90 0x96df6da8 0xb6374c 0x18bf8c 0x171ca8 0x17b4e8 0x17ccec 0x171750 0x16e954)
2012-12-28 08:46:47.681 blender[260:807] *** _NSAutoreleaseNoPool(): Object 0x73a85d0 of class NSCFArray autoreleased with no pool in place - just leaking
Stack: (0x975aadac 0x974d7e14 0x96b7156c 0x96c48730 0x96b820f4 0x96df6da8 0xb6374c 0x18bf8c 0x171ca8 0x17b4e8 0x17ccec 0x171750 0x16e954)
found bundled python: /Users/Papa/Applications/blender-2.63/blender.app/Contents/MacOS/2.63/python
addon_utils.disable csv_fcurve_importer not loaded
addon_utils.disable csv_mesh_importer not loaded
Python 3.2 is already installed and Blender 2.63.
I also tried to specify the Scripts path, but it doesn't change anything.
I can see the scripts in the users preferences/addons window, but impossible to active then, they aren't loaded Sad
I already had the trouble with former versions and even with my Intel MacBookPro (still under 10.5.Cool. Unfortunately I can't upgrade my Macs to go up to 10.6.
Jump to:
