Posted: Fri Oct 25, 2002 1:49 pm
Ive installed publisher with the licence key on other computers just fine but the at home (windows ME) a message comes up not valid key, deleting current key. Does anyone know what I have to do. Thanks in advance.
Posted: Fri Oct 25, 2002 3:22 pm
Try downloading the key again.
Posted: Sat Oct 26, 2002 12:16 am
Did you copy blender from an exitsting copy or did you install it freash from the d/l.
I had the same problem when I copyed the files from one comp to another. I just d/l that whole thing again, and it worked.
~Geoffrey~
Posted: Sat Oct 26, 2002 1:00 am
if you copied it from another system, then yeah you'll get that problem.
the installer it puts a small registry entry in windows that has the key in it.
this can't be moved, you'll have to install a fresh copy.
_________________
dittohead
Posted: Sat Oct 26, 2002 8:23 pm
Be careful not to edit the file when copying, this includes 'doze bad habit of replacing \r with \r\n
Posted: Wed Oct 30, 2002 8:05 am
I had the same problem...
I solved it by simply making adding the key.dat file that worked to a zip file. I copied the zip to the other computer and unzipped it... It worked fine
