Hello,
I'm looking for a way to apply the same texture area (selected in uv editor) of a given material to several faces at once (for example on a pipe or any object with many faces with the same texture).
Thanks for your help.
Hello,
This is not possible?
I'd need a script to do it?
Hello,
I found a way to do it:
With addon 'space_view3d_copy_attributes.py' (Copy Attributes Menu)
Go into edit mode
Select all faces to be textured including the face which texture you want to copy
Shift select face which texture you want to copy
Ctrl C
Copy Material
Ctrl C
Copy Image
Ctrl C
Copy UV Coordinates
