Previous Thread  Next Thread
chat icon Interactive transform from script
linsnos
Posted: Wed Nov 14, 2012 9:49 am
Hi!
I'm trying to scale an active and selected vertex group via an UI Panel with a custom property. I tried using bpy.ops.transform.resize and bpy.ops.transform.transform in the update method of the custom property. That did not work well, since each time the property is changed by the user in the panel, the transform is applied on the last transformed mesh, incrementally.
I would like to find a way to let the user scale the mesh interactively in the same way as when the key S is used. Is that possible? Is there a python modal operator I have missed?
/Tobias
CoDEmanX
Posted: Wed Nov 14, 2012 12:18 pm
transform operators are C live operators, you can call them via python like
bpy.ops.transform.resize('INVOKE_DEFAULT')
but your operator must then be called from 3d view (spacebar menu or operator button from 3d view's tool panel)
you can write your own modal python operators, but they will run way less responsive compared to C operators.
_________________
CoDEmanX
Posted: Wed Nov 14, 2012 12:49 pm
here's an example:
Code:
import bpy
def main(context):
    for ob in context.scene.objects:
        print(ob)
class SimpleOperator2(bpy.types.Operator):
    """Tooltip"""
    bl_idname = "object.simple_operator2"
    bl_label = "Simple Object Operator2"
    @classmethod
    def poll(cls, context):
        return context.active_object is not None
    def execute(self, context):
        context.object.location.y += 1
        return {'FINISHED'}
class SimpleOperator(bpy.types.Operator):
    """Tooltip"""
    bl_idname = "object.simple_operator"
    bl_label = "Simple Object Operator"
    @classmethod
        #main(context)
        bpy.ops.mesh.select_all(action='SELECT')
        print(bpy.ops.transform.resize('INVOKE_DEFAULT'))
        bpy.ops.mesh.select_all(action='DESELECT')
        context.object.location.z += 2
        print(context.active_operator)
        bpy.ops.object.simple_operator2()
        return {'FINISHED'}
def register():
    bpy.utils.register_class(SimpleOperator)
    bpy.utils.register_class(SimpleOperator2)
def unregister():
    bpy.utils.unregister_class(SimpleOperator)
    bpy.utils.unregister_class(SimpleOperator2)
if __name__ == "__main__":
    register()
    # test call
    #bpy.ops.object.simple_operator()
the problem is, that the last operator has already been executed while the transform is running. Same applies to changes to the object (z-location).
_________________
linsnos
Posted: Wed Nov 14, 2012 3:10 pm
Thank you very much!
I will try it out and see the effects.
Jump to:
