Posted: Wed Nov 21, 2012 11:14 am
Hello,
It is possible to do that?:
Separate by loosed parts and export them to dxf files.
The question:
It is possible to apply lasso selection using detected loosed part edges and create for example rectangle and circle inside them as one loosed part and then export to dxf?
Thank you
Posted: Wed Nov 21, 2012 2:12 pm
you can select lose edges and verts, and you can separate by loose parts.
I don't understand what you wanna do after that...
_________________
Posted: Wed Nov 21, 2012 2:44 pm
I want to to this using script.
It must be exported to dxf when is separated
Posted: Wed Nov 21, 2012 4:18 pm
well, how about
| Code: |
import bpy
if bpy.context.object:
bpy.ops.object.mode_set(mode='OBJECT')
bpy.ops.object.select_all(action='DESELECT')
ob = bpy.data.objects['YourUnseparatedOb']
bpy.context.scene.objects.active = ob
ob.select = True
bpy.ops.object.mode_set(mode='EDIT')
bpy.ops.mesh.separate(type='LOOSE')
if not bpy.context.user_preferences.addons.get('io_export_dxf', False):
bpy.ops.wm.addon_enable(module="io_export_dxf")
bpy.ops.export.dxf(filepath="C:\\the\\filepath\\filename.ext", projectionThrough='NO', onlySelected=True, apply_modifiers=True, mesh_as='3DFACEs', entitylayer_from='obj.data.name', entitycolor_from='default_COLOR', entityltype_from='CONTINUOUS', layerName_from='LAYERNAME_DEF', verbose=False)
_________________
Posted: Wed Nov 21, 2012 8:49 pm
Coll!
That are first and last steps I want to do.
I need to save separated parts to different dxf files, after object is separated using command bpy.ops.mesh.separate(type='LOOSE').
Object like in the example below must be joined again and saved as one object.
This is description why do I need this script:
1. I want to import puzzle dxf file for laser cutting
2. Later, I want to separate object into separated puzzle elements
3. Object like this wheel (picture above) must be joined again, because that is one puzzle element.
4. Objects must be saved to different dxf files. Later that dxf files will be imported to ProNest for cutting area optimization and this process is not related with Blender.
....................not be included in my script..................
5. In the next step on the puzzle elements (already separated) will be added faces.
6. Then they will be extruded.
7. Then will be added textures and will be created puzzle assembly animation
