How to make animation of strocking object's edge ?
YQ-YSY
Postby YQ-YSY » Thu Dec 13, 2012 3:30 am
How to make animation of strocking object's edge as same as curve's bevel ?
I have a object, I want to make a animation -- strocking the object's edge.
I hope it seems like writing or drawing the object's edge.
Is there has a simple way to achieve it?
I hope the strock animtion like curve's bevel object, can set the keyframe of start or end becel factor...
YQ-YSY
Postby YQ-YSY » Fri Dec 14, 2012 2:58 am
I found a way:
Cube => Edit mode => Delete only faces => Object mode =>Alt C => Curve from Mesh/Text
So can choice bevel object and insert the keyframe in Strat/End Bevel Factor make animation.
but there is another problem: the animation will start at 4 vertices in the same time, not one by one.
maybe must sepaate them became new curve object ? can I sort vertices in curve?
kaushalsingh
Postby kaushalsingh » Mon Dec 17, 2012 4:34 pm
You can try to photoshop it...that might help you to get edge as same as curve's bevel
Best of luck :D
norvman
Postby norvman » Fri Jan 04, 2013 2:00 am
I think I saw a tutorial over at Blender Diplom that about using lightstreaks that might be of you use to what your trying to do...
Return to “Animation”
