| Code: |
| PYTHON INTERACTIVE CONSOLE 3.3.0 (default, Sep 29 2012, 17:18:27) [GCC 4.7.2]
Command History: Up/Down Arrow Cursor: Left/Right Home/End Remove: Backspace/Delete Execute: Enter Autocomplete: Ctrl+Space Ctrl +/- Wheel: Zoom Builtin Modules: bpy, bpy.data, bpy.ops, bpy.props, bpy.types, bpy.context, bpy.utils, bgl, blf, mathutils Convenience Imports: from mathutils import *; from math import * Convenience Variables: C = bpy.context, D = bpy.data >>> bpy.ops.export.md3(filepath=".md3") ######################BEGIN###################### Exporting selected objects... Error: Traceback (most recent call last): File "/home/alejandro/.config/blender/2.65/scripts/addons/io_mesh_md3/export_md3_15.py", line 316, in execute save_md3(settings) File "/home/alejandro/.config/blender/2.65/scripts/addons/io_mesh_md3/export_md3_15.py", line 170, in save_md3 for f,face in enumerate(nobj.faces): AttributeError: 'Mesh' object has no attribute 'faces' Error in sys.excepthook: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 64, in apport_excepthook from apport.fileutils import likely_packaged, get_recent_crashes File "/usr/lib/python3/dist-packages/apport/__init__.py", line 4, in <module> from apport.report import Report File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in <module> import apport.fileutils File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in <module> from apport.packaging_impl import impl as packaging File "/usr/lib/python3/dist-... truncated Traceback (most recent call last): File "/usr/lib/python3.3/code.py", line 90, in runcode exec(code, self.locals) File "<blender_console>", line 1, in <module> File "/usr/share/blender/2.65/scripts/modules/bpy/ops.py", line 188, in __call__ ret = op_call(self.idname_py(), None, kw) RuntimeError: Error: Traceback (most recent call last): File "/home/alejandro/.config/blender/2.65/scripts/addons/io_mesh_md3/export_md3_15.py", line 316, in execute save_md3(settings) File "/home/alejandro/.config/blender/2.65/scripts/addons/io_mesh_md3/export_md3_15.py", line 170, in save_md3 for f,face in enumerate(nobj.faces): AttributeError: 'Mesh' object has no attribute 'faces' Error in sys.excepthook: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 64, in apport_excepthook from apport.fileutils import likely_packaged, get_recent_crashes File "/usr/lib/python3/dist-packages/apport/__init__.py", line 4, in <module> from apport.report import Report File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in <module> import apport.fileutils File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in <module> from apport.packaging_impl import impl as packaging File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 20, in <module> import apt File "/usr/lib/python3/dist-packages/apt/__init__.py", line 21, in <module> import apt_pkg ImportError: No module named 'apt_pkg' Original exception was: Traceback (most recent call last): File "/home/alejandro/.config/blender/2.65/scripts/addons/io_mesh_md3/export_md3_15.py", line 316, in execute save_md3(settings) File "/home/alejandro/.config/blender/2.65/scripts/addons/io_mesh_md3/export_md3_15.py", line 170, in save_md3 for f,face in enumerate(nobj.faces): AttributeError: 'Mesh' object has no attribute 'faces' location: /usr/share/blender/2.65/scripts/modules/bpy/ops.py:188 Traceback (most recent call last): File "/usr/lib/python3.3/code.py", line 90, in runcode exec(code, self.locals) File "<blender_console>", line 1, in <module> File "/usr/share/blender/2.65/scripts/modules/bpy/ops.py", line 188, in __call__ ret = op_call(self.idname_py(), None, kw) RuntimeError: Error: Traceback (most recent call last): File "/home/alejandro/.config/blender/2.65/scripts/addons/io_mesh_md3/export_md3_15.py", line 316, in execute save_md3(settings) File "/home/alejandro/.config/blender/2.65/scripts/addons/io_mesh_md3/export_md3_15.py", line 170, in save_md3 for f,face in enumerate(nobj.faces): AttributeError: 'Mesh' object has no attribute 'faces' Error in sys.excepthook: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 64, in apport_excepthook from apport.fileutils import likely_packaged, get_recent_crashes File "/usr/lib/python3/dist-packages/apport/__init__.py", line 4, in <module> from apport.report import Report File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in <module> import apport.fileutils File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in <module> from apport.packaging_impl import impl as packaging File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 20, in <module> import apt File "/usr/lib/python3/dist-packages/apt/__init__.py", line 21, in <module> import apt_pkg ImportError: No module named 'apt_pkg' Original exception was: Traceback (most recent call last): File "/home/alejandro/.config/blender/2.65/scripts/addons/io_mesh_md3/export_md3_15.py", line 316, in execute save_md3(settings) File "/home/alejandro/.config/blender/2.65/scripts/addons/io_mesh_md3/export_md3_15.py", line 170, in save_md3 for f,face in enumerate(nobj.faces): AttributeError: 'Mesh' object has no attribute 'faces' location: /usr/share/blender/2.65/scripts/modules/bpy/ops.py:188 During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/share/blender/2.65/scripts/modules/console_python.py", line 161, in execute is_multiline = console.push(line_exec) File "/usr/lib/python3.3/code.py", line 256, in push more = self.runsource(source, self.filename) File "/usr/lib/python3.3/code.py", line 74, in runsource self.runcode(code) File "/usr/lib/python3.3/code.py", line 94, in runcode self.showtraceback() File "/usr/lib/python3.3/code.py", line 157, in showtraceback sys.excepthook(type, value, tb) File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 64, in apport_excepthook from apport.fileutils import likely_packaged, get_recent_crashes File "/usr/lib/python3/dist-packages/apport/__init__.py", line 4, in <module> from apport.report import Report File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in <module> import apport.fileutils File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in <module> from apport.packaging_impl import impl as packaging File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 20, in <module> import apt File "/usr/lib/python3/dist-packages/apt/__init__.py", line 21, in <module> import apt_pkg ImportError: No module named 'apt_pkg' >>> |
