Problem importing SMD
Segadordelinks
Postby Segadordelinks » Mon Dec 17, 2012 7:16 pm
Hi there.
I've been using Blender 2.63a for a time with no problem. When 2.65 was released I wanted to update it (the Transfer Weights feature was very interesting), so I tried it but I found a problem.
When I want to import a .smd file (SMD Tools 1.5.2 & 1.6.2) this error message appears.
File "C:\Program Files\Blender Foundation\Blender\2.65\scripts\addons\io_smd_tools.py", line 1934, in execute
self.countSMDs = readSMD(context, self.properties.filepath, self.properties.upAxis, self.properties.rotMode, append=self.properties.append)
File "C:\Program Files\Blender Foundation\Blender\2.65\scripts\addons\io_smd_tools.py", line 1562, in readSMD
if line == "triangles\n": readPolys()
File "C:\Program Files\Blender Foundation\Blender\2.65\scripts\addons\io_smd_tools.py", line 1183, in readPolys
removeDoublesPreserveFaces()
File "C:\Program Files\Blender Foundation\Blender\2.65\scripts\addons\io_smd_tools.py", line 1036, in removeDoublesPreserveFaces
ops.mesh.remove_doubles(mergedist=0)
File "C:\Program Files\Blender Foundation\Blender\2.65\scripts\modules\bpy\ops.py", line 188, in __call__
ret = op_call(self.idname_py(), None, kw)
TypeError: Converting py args to operator properties: : keyword "mergedist" unrecognized
The model appears, but the vertex are messed up. Where there should be a vertex common for various faces, appears a different vertex for every face.
That happened to me before (in version 2.63a), but only when I imported it while in Edit Mode. Now it happens every time, and realised that the main view changes automatically to Edit Mode.
I uninstalled and installed from scratch several times. Tried different versions (with and without installer, 32 & 64 bits).
Can someone help me? Thanks in advance.
Tehrasha
Postby Tehrasha » Mon Dec 17, 2012 7:45 pm
Blender 2.65 changed some things that break the smd importer, the author thinks he has a fix for it, but hasnt finalized the change yet.
You can get the patched version which should work, here...
http://code.google.com/p/blender-smd/so ... tail?r=300
(keep an eye open, he will probably release this as an official fix within 24hrs)
Spacemice Wiki -- Input devices for a 3D world.
Spacemice / Blender Compatibility
Segadordelinks
Postby Segadordelinks » Mon Dec 17, 2012 10:11 pm
Thanks for the quick answer :D
Slinet_Garden
Postby Slinet_Garden » Thu Mar 14, 2013 9:21 pm
Tehrasha wrote:Blender 2.65 changed some things that break the smd importer, the author thinks he has a fix for it, but hasnt finalized the change yet.
Hi i have the same problem but the links are dead so pls answer me or send me a link :(
Tehrasha
Postby Tehrasha » Fri Mar 15, 2013 1:33 am
Slinet_Garden wrote:Hi i have the same problem but the links are dead so pls answer me or send me a link :(
Link still works fine from here...
Try this... http://code.google.com/p/blender-smd/downloads/list
Return to “Interface & Tools”
