Method of shading in the 3D display
Foxtrot
Postby Foxtrot » Wed Dec 26, 2012 11:27 pm
Hi I've just discovered Blender and was running through a few basic tutorials when I came across a problem which will cause me a world of trouble later on. When I select the shading in the 3D display as a 'solid' I can still see through the objects causing me to select faces on the other side of the object that I don't want too. Is there something I need to switch on or off in the user interface preferences, because if there is I can't find it.
Hope someone can help me out on this one
Chavar
Re: Method of shading in the 3D display
Postby Chavar » Fri Dec 28, 2012 12:28 am
Sure, no problem. Toggle the "limit selection to visible" switch located on the lower panel of the 3D viewer.
See link below.
https://www.dropbox.com/s/a264tpdf0823i ... isible.jpg
Chavar
Postby Chavar » Fri Dec 28, 2012 12:30 am
Chavar wrote:Sure, no problem. Toggle the "limit selection to visible" switch located on the lower panel of the 3D viewer.
See link below.
The toggle switch will only be activated in edit mode of course.
Regards
Foxtrot
Postby Foxtrot » Sat Dec 29, 2012 12:13 pm
Thanks Chavar, that saved me a load time. Its so easy when you know how. Happy Blending my friend :D
Chavar
Postby Chavar » Sat Dec 29, 2012 3:24 pm
Sure no prob, cheers. :)
Return to “Interface & Tools”
