| Code: |
| [ 78%] Generating kernel_sm_11.cubin
/opt/src/blender/intern/cycles/kernel/svm/svm.h(182): Warning: Pointer parameters must be inlined, so overriding noinline attribute on '_Z14svm_eval_nodesP13KernelGlobalsP10ShaderData10ShaderTypefi' /tmp/tmpxft_000054f5_00000000-10_kernel.cpp3.i(0): Warning: Optimizing huge function kernel_cuda_path_trace because Olimit has been overridden; compiler may run out of memory or run very slowly nvopencc ERROR: /usr/local/cuda-5.0/open64/lib//be died due to signal 9 nvopencc ERROR: Probably caused by running out of swap space -- check /var/log/messages make[2]: *** [intern/cycles/kernel/kernel_sm_10.cubin] Error 1 make[2]: *** Ожидание завершения заданий... |
