FloatVectorProperty
kollmanj
FloatVectorProperty
Postby kollmanj » Sat Jan 26, 2013 7:37 pm
I can't figure out how to use: FloatVectorProperty
Code: Select all
    blocation = FloatVectorProperty(name="Becon Location",
        description="Becon Location",
        default=(0.0, 0.0, 0.0),
        min=(0.0,0.0,0.0),
        max=(100.0,100.0,100.0),
        step=3,
        precision=2,
        options={'ANIMATABLE'},
        subtype='TRANSLATION',
        size=3,
        update=None,
        get=None,
        set=None
my_z = blocation[2]
ERROR:
IndexError: tuple index out of range
How do I get the values entered by the user?
:P
CoDEmanX
Postby CoDEmanX » Sun Jan 27, 2013 12:30 am
you need to use an instance of a property, not the property definition.
It basically means, that (inside the same class) you need to access the property like
Code: Select all
self.blocation
or if it's defined on "global level" like
Code: Select all
bpy.types.Scene.blocation = ...
then you can access the currently relevant instance like
Code: Select all
bpy.context.scene.blocation
kollmanj
still confused
Postby kollmanj » Sun Jan 27, 2013 1:26 am
Here is the code:
Code: Select all
print(self.blocation)
Here is the output:
(<built-in function FloatVectorProperty>, {'name': 'Becon Location', 'step': 3,
'set': None, 'options': {'ANIMATABLE'}, 'default': (0.0, 0.0, 0.0), 'description
': 'Becon Location', 'precision': 2, 'size': 3, 'max': (100.0, 100.0, 100.0), 'g
et': None, 'subtype': 'TRANSLATION', 'min': (0.0, 0.0, 0.0), 'update': None})
what do I do with that?
Thanks, for the reply but I'm still confused I must be missing something. :oops:
kollmanj
Postby kollmanj » Sun Jan 27, 2013 4:05 am
I think I'll just go with FloatProperty because I can't get this vectorproperty to work. But I thought I'd post this just to see if anyone can enlighten me. I'm going to list some code. The stuff related to FloatProperty works but the stuff related to FloatVectorProperty does not. Maybe someone can explain this mess, maybe not. :(
Code: Select all
    room_width =  FloatProperty(name="Room Width",
        description="Room Width",
        min=1.0,
        max=10,
        default=3)
    location = FloatVectorProperty(name="Receiver Location",
        description="Receiver Location",
        min=(0.0,0.0,0.0),
        step=3,
        precision=2,
        subtype='NONE',
        size=3,
        update=None,
        get=None,
        set=None)
        min=(0.0,0.0,0.0),
        step=3,
        precision=2,
        size=3,
        update=None,
        get=None,
        set=None)
    crap =    FloatVectorProperty(attr="myColorValue", min=0, max=1, default=0, name="myColor", description="my cool color value i can use for anything i like", subtype="COLOR")
    def draw(self, context):
        layout = self.layout
        box = layout.box()
        box.prop(self, 'room_length')
        box.prop(self, 'room_width')
        box.prop(self, 'location')
        box.prop(self, 'blocation')
        box = layout.box()
        layout.prop(context.material, "myColorValue")
CoDEmanX
Postby CoDEmanX » Sun Jan 27, 2013 9:45 pm
one usually gets something like:
if one tries to add a property to an unsupported type (non-ID/bone/posebone type)
or if one accesses the property wrong (the variable, instead of the property instance)
Return to “Coding Blender”
