Align new objects "to view" not working: GUI menu
Postby boblishman » Thu Jan 31, 2013 10:20 am
Is this just a "fault" with the 2.65 build, or is it deliberate?
When I change the user preferences in the EDITING tab to
New Objects:
Align to: VIEW
this DOES NOT make new objects added to a scene align to the 3D window's current view if I use the GUI's MENU/ADD/ method ... and they are still added in WORLD view .... :x
However, if I use the SHIFT+A method to add a new object, that DOES work.
(This is not just limited to meshes, but ALL objects added using the MENU method.)
I do realise that the wording of the tooltip says "from a 3D view menu" and that's why I am asking if this is "by design"
Why is this User Preference Option limited to the SHIFT+A method and not ALSO applied to the MENU method of adding new objects ? ? ?
Can I change this somehow (as I never use SHIFT+A to add stuff) ?
Any response to the above inquiry would still helpful
Postby stellar » Mon Aug 12, 2013 9:00 pm
I too have the same exact question! :?
Postby stiv » Tue Aug 13, 2013 12:35 am
1st question: does the problem show up with official 2.68a (latest ver)?
It has to do with the way context is passed to the op.
Postby dustractor » Fri Aug 16, 2013 5:47 pm
Spend any amount of time scripting and you will run into this problem.
When operators are run there are various types of execution context such as whether to invoke or execute and from which level of the UI to take the context from. This could be as general as the whole window, or as specific as the particular region where the mouse is at. Windows have screens which have areas which have spaces which have regions which have various types of space data and region data associated.
In other words, it gets complicated.
An operator like the one in question expects to be run in the viewport. expects such and such context. The menu items on the top are actually part of the 'INFO' space, not the 'VIEW_3D' space. When the operator is run from that area -- close but no cigar.
Asks for an area, a region, a space, a screen, a window... gets the wrong one.
Perhaps this could be considered a bug. Not of the operator but the UI. In the INFO_MT_add menu. Here it is, excerpted from
Code: Select all
class INFO_MT_add(Menu):
    bl_label = "Add"
    def draw(self, context):
        layout = self.layout
        # note, don't use 'EXEC_SCREEN' or operators wont get the 'v3d' context.
        # Note: was EXEC_AREA, but this context does not have the 'rv3d', which prevents
        #       "align_view" to work on first call (see [#32719]).
        layout.operator_context = 'EXEC_REGION_WIN'
        #layout.operator_menu_enum("object.mesh_add", "type", text="Mesh", icon='OUTLINER_OB_MESH')"INFO_MT_mesh_add", icon='OUTLINER_OB_MESH')
        #layout.operator_menu_enum("object.curve_add", "type", text="Curve", icon='OUTLINER_OB_CURVE')"INFO_MT_curve_add", icon='OUTLINER_OB_CURVE')
        #layout.operator_menu_enum("object.surface_add", "type", text="Surface", icon='OUTLINER_OB_SURFACE')"INFO_MT_surface_add", icon='OUTLINER_OB_SURFACE')
        layout.operator_menu_enum("object.metaball_add", "type", text="Metaball", icon='OUTLINER_OB_META')
        layout.operator("object.text_add", text="Text", icon='OUTLINER_OB_FONT')
        layout.separator()"INFO_MT_armature_add", icon='OUTLINER_OB_ARMATURE')
        layout.operator("object.add", text="Lattice", icon='OUTLINER_OB_LATTICE').type = 'LATTICE'
        layout.operator_menu_enum("object.empty_add", "type", text="Empty", icon='OUTLINER_OB_EMPTY')
        layout.operator("object.speaker_add", text="Speaker", icon='OUTLINER_OB_SPEAKER')
        layout.operator("object.camera_add", text="Camera", icon='OUTLINER_OB_CAMERA')
        layout.operator_menu_enum("object.lamp_add", "type", text="Lamp", icon='OUTLINER_OB_LAMP')
        layout.operator_menu_enum("object.effector_add", "type", text="Force Field", icon='OUTLINER_OB_EMPTY')
        if len( > 10:
            layout.operator_context = 'INVOKE_REGION_WIN'
            layout.operator("object.group_instance_add", text="Group Instance...", icon='OUTLINER_OB_EMPTY')
            layout.operator_menu_enum("object.group_instance_add", "group", text="Group Instance", icon='OUTLINER_OB_EMPTY')
Return to “Interface & Tools”
