Posted: Sun Feb 03, 2013 4:42 pm
Hello,
Can anyone explain the material property mapping used to export x3d scenes.
The writeMaterial function tweaks blender material properties a lot before exporting them and these tweaks cannot be inverted.
export_x3d.py :
| Code: |
def writeMaterial(ident, material, world):
material_id = quoteattr(unique_name(material, MA_ + material.name, uuid_cache_material, clean_func=clean_def, sep="_"))
# look up material name, use it if available
if material.tag:
fw('%s<Material USE=%s />\n' % (ident, material_id))
else:
material.tag = True
emit = material.emit
ambient = material.ambient / 3.0
diffuseColor = material.diffuse_color[:]
if world:
ambiColor = ((material.ambient * 2.0) * world.ambient_color)[:]
else:
ambiColor = 0.0, 0.0, 0.0
emitColor = tuple(((c * emit) + ambiColor[i]) / 2.0 for i, c in enumerate(diffuseColor))
shininess = material.specular_hardness / 512.0
specColor = tuple((c + 0.001) / (1.25 / (material.specular_intensity + 0.001)) for c in material.specular_color)
transp = 1.0 - material.alpha
if material.use_shadeless:
ambient = 1.0
shininess = 0.0
specColor = emitColor = diffuseColor
ident_step = ident + (' ' * (-len(ident) + \
fw('%s<Material ' % ident)))
fw('DEF=%s\n' % material_id)
fw(ident_step + 'diffuseColor="%.3f %.3f %.3f"\n' % clamp_color(diffuseColor))
fw(ident_step + 'specularColor="%.3f %.3f %.3f"\n' % clamp_color(specColor))
fw(ident_step + 'emissiveColor="%.3f %.3f %.3f"\n' % clamp_color(emitColor))
fw(ident_step + 'ambientIntensity="%.3f"\n' % ambient)
fw(ident_step + 'shininess="%.3f"\n' % shininess)
fw(ident_step + 'transparency="%s"\n' % transp)
fw(ident_step + '/>\n')
Thank's
Posted: Sun Feb 03, 2013 5:31 pm
Not sure what you are referring to specifically, but I suspect the 'tweaks' are to translate from one set of metaphors to another.
The main issue with import/export is not converting the numbers, but translating from the way one program looks at the world to another's view. Examples might be simple, like converting from Z pointing up to Z pointing into the screen. A more complex example might be converting from Blender's view of Materials and Textures being separate entities to one where Material encapsulates both concepts.
Posted: Sun Feb 03, 2013 6:04 pm
My main problem is I can't reproduce blender rendering using data from x3d export.
X3D specification doesn't suggest these tweaks are required and I think there are wrong. However I'm not a blender specialist and maybe I'm misunderstanding something.
http://www.web3d.org/files/specifications/19775-1/V3.2/Part01/components/lighting.html#Lightingmodel
X3D just uses a standard Blinn model with light attenuation and Blender seems to use the exact same one (if we configure materials with Lambert+Blinn).
The most disturbing parts of writeMaterial are the emissive color and the specular color :
| Code: |
| Code: |
Why not :
| Code: |
emitColor = emit * diffuseColor
| Code: |
specColor = material.specular_color * material.specular_intensity
Posted: Mon Feb 04, 2013 8:28 pm
Should I move this question in another section ?
Posted: Mon Feb 04, 2013 9:17 pm
i don't think that's a problem, rather no one can give you an answer. Maybe try to find a dev who knows (probably ideasman42) on IRC, freenode.net #blendercoders
_________________
Posted: Tue Feb 05, 2013 11:45 am
| CoDEmanX wrote: |
| i don't think that's a problem, rather no one can give you an answer. Maybe try to find a dev who knows (probably ideasman42) on IRC, freenode.net #blendercoders |
Thank's !
