I have a few outlines that I imported into blender via python. Basically they are made up of vertices connected by edges, that are cyclic (i.e. closed). If I extrude them, I'm able to create a cylinder'oid with the outline and that works great.
But what I need is to be able to cap the solid, i.e. close the top and/or bottom of the object. Now if the outlines were convex I just needed to extrude once again, scale the last extruded points to zero, remove duplicates and that would be it. Obviously this does not work on a concave outline as you get triangles covering the holes.
I read that you cannot create curves from Python, so I can't go via there. So is there a way to automatically triangulate an outline (which is, in blender terms, a mesh)? Does anyone maybe have a script that does that?
Please let me know...
Thanks in advance,
Miguel
I have python code to triangulate an n-sided convex polygon, but I don't think it will help you.
Why don't you just select your concave mesh outline, enter edit mode, and press
shift-f? Then
alt-f a few times to make it look better.
__
http://ourworld.compuserve.com/homepages/scorpius
By the way, what outlines are you importing? Adobe Illustrator? I'd be curious to have a look at your script.
