Previous Thread  Next Thread
chat icon bf-blender / Linux glibc 2.3.2 (2004/01/06)
kino
Posted: Tue Jan 06, 2004 12:28 am
scons system, no TTF , no Gameengine
Link : removed, use new builds
Log:
SCons updates:
* Removed debug print in ftfont.
* Added FreeType/FTGL support to the Linux build.
NOTE: This feature is on by default, but depends on the pre-build libraries.
So checkout the lib directory. The lib dir should be on the same level as
the blender dir. (In case you didn't know). *
Log:
- belonging to previous commit... correct splitting into triangles
when quads are not planar.
* - ther's no ftgl for glibc2.3.2 in the cvs i cannot compile with ttf i have error with 2.2.5 Smile
_________________
kino3d.com italian site
Michel
Posted: Tue Jan 06, 2004 8:26 am
Kino,
that's weird. I myself have glibc 2.3.3. And I have compiled blender with the glibc 2.2.5 versions of ftgl and freetype. It should work. If not, please post the link errors here and I'll see what I can do. As a last resort I could disable the International support for a while.
With regards,
Michel
_________________
You can have one of two things: Progress or Progress Reports.
kino
Posted: Tue Jan 06, 2004 11:43 am
Hi Michel
My system
Suse 8.2
glibc 2.3.2
gcc 3.3
I learned how to disable in the SConstruc file
the compile of FTGL and how to change library
i have checkout the library dir from the cvs
and is at the same level of the blender dir
the error is at the end of the compile
g++ -pipe -fPIC -funsigned-char -O2 -Wall -W -DINTERNATIONAL
-DFTGL_STATIC_LIBRARY -DWITH_FREETYPE2 -Isource/blender/ftfont
-I/home/kino/develop/lib/linux-glibc2.2.5-i386/ftgl/include
-I/home/kino/develop/lib/linux-glibc2.2.5-i386/freetype/include
-Isource/blender/ftfont -Isource/blender/ftfont/intern
-Isource/blender/blenlib -Isource/blender/makesdna -c -o
source/blender/ftfont/intern/FTF_TTFont.o
source/blender/ftfont/intern/FTF_TTFont.cpp
source/blender/ftfont/intern/FTF_TTFont.cpp: In constructor `
FTF_TTFont::FTF_TTFont()':
source/blender/ftfont/intern/FTF_TTFont.cpp:114: warning: NULL used in
arithmetic source/blender/ftfont/intern/FTF_TTFont.cpp:117: warning:
NULL used in arithmetic
source/blender/ftfont/intern/FTF_TTFont.cpp:134: warning: NULL used in
arithmetic
source/blender/ftfont/intern/FTF_TTFont.cpp: In member function `int
FTF_TTFont::TransConvString(char*, char*, unsigned int)':
source/blender/ftfont/intern/FTF_TTFont.cpp:264: warning: unused
parameter ` char*str'
parameter ` char*ustr'
parameter ` unsigned int flag'
ar r lib/libblender_FTF.a source/blender/ftfont/intern/FTF_Api.o
source/blender/ftfont/intern/FTF_TTFont.o ranlib lib/libblender_FTF.a
gcc -o blender source/creator/buildinfo.o source/creator/creator.o
-L/usr/lib -Llib -L/usr/lib/python2.2/config -L.
-L/home/kino/develop/lib/linux-glibc2.2.5-i386/ftgl
-L/home/kino/develop/lib/linux-glibc2.2.5-i386/freetype/lib -lSDL
-lpthread -lblender_render -lblender_yafray -lblender_blendersrc
-lblender_renderconverter -lblender_blenloader -lblender_writestreamglue
-lblender_deflate -lblender_writeblenfile -lblender_readblenfile
-lblender_readstreamglue -lblender_inflate -lblender_img
-lblender_radiosity -lblender_blenkernel -lblender_blenpluginapi
-lblender_imbuf -lblender_avi -lblender_blenlib -lblender_python
-lblender_makesdna -lblender_kernel -lblender_BSP -lblender_LOD
-lblender_GHOST -lblender_STR -lblender_guardedalloc -lblender_BMF
-lblender_CTR -lblender_MEM -lblender_IK -lblender_MT -lsoundsystem
-lblender_FTF -lpython2.2 -lm -lz -lGL -lGLU -lpng -ljpeg -lutil -lftgl
-lfreetype/usr/lib/python2.2/config/libpython2.2.a(posixmodule.o)(.text
+0x3512): In function
`posix_tmpnam':/home/kino/develop/Python/Python-2.2.2/Modules/posixmodu
le.c:4505: the use of `tmpnam_r' is dangerous, better use
`mkstemp'/usr/lib/python2.2/config/libpython2.2.a(posixmodule.o)(.text+
0x342d): In function
`posix_tempnam':/home/kino/develop/Python/Python-2.2.2/Modules/posixmod
ule.c:4455: the use of `tempnam' is dangerous, better use `mkstemp'
lib/libblender_FTF.a(FTF_TTFont.o)(.text+0x5b4): In function
`FTF_TTFont::SetFont(char*, int)':: undefined reference to
`FTGLPixmapFont::FTGLPixmapFont[in-charge](char const*)'
lib/libblender_FTF.a(FTF_TTFont.o)(.text+0x60a): In function
lib/libblender_FTF.a(FTF_TTFont.o)(.text+0x62a): In function
lib/libblender_FTF.a(FTF_TTFont.o)(.text+0x6ba): In function
`FTFont::CharMap(FT_Encoding_)'
lib/libblender_FTF.a(FTF_TTFont.o)(.text+0x6cd): In function
lib/libblender_FTF.a(FTF_TTFont.o)(.text+0x6e0): In function
lib/libblender_FTF.a(FTF_TTFont.o)(.text+0x8fe): In function
`FTF_TTFont::Ascender()':: undefined reference to `FTFont::Ascender()
const' lib/libblender_FTF.a(FTF_TTFont.o)(.text+0x93e): In function
`FTF_TTFont::Descender()':: undefined reference to `FTFont::Descender()
const' lib/libblender_FTF.a(FTF_TTFont.o)(.text+0xa58): In function
`FTF_TTFont::DrawString(char*, unsigned)':: undefined reference to
`FTFont::Advance(wchar_t const*)'
lib/libblender_FTF.a(FTF_TTFont.o)(.text+0xadc): In function
`FTF_TTFont::GetStringWidth(char*, unsigned)':: undefined reference to
lib/libblender_FTF.a(FTF_TTFont.o)(.text+0xb08): In function
lib/libblender_FTF.a(FTF_TTFont.o)(.text+0xb95): In function
`FTF_TTFont::GetBoundingBox(char*, float*, float*, float*, float*,
float*, float*, unsigned)':: undefined reference to
`FTFont::BBox(wchar_t const*, float&, float&, float&, float&, float&,
float&)' collect2: ld returned 1 exit status
scons: *** [blender] Error 1
scons: building terminated because of errors.
i have checkout the library with
cvs -z3 up -d -P -d linux-glibc2.2.5-i386/
if i change in SCronstruc file
use_international = 'false'
compilation go well
ciao
_________________
Michel
Posted: Tue Jan 06, 2004 4:08 pm
ugh, this gives me more information than you're aware Laughing
The above tells me that I'm passing the wrong variables to a SConscript file. It doesn't seem to affect your build at this point though. But the SConscript is not nice. TODO for Michel Wink
-lfreetype
Hrm, that's weird. I see you have -L. in your library path somewhere. This shouldn't be the case. Did you add it yourself? Or is there indeed a needed library located in the root of the source tree of blender on your system?
`mkstemp'
Nothing to worry about the above 2 warnings. This is because of Python. With Python 2.3, these are gone, but unfortunately some compiler warnings are introduced as well with Python 2.3. Nothing for you to worry about.
<snip>
I'll have a look at it tomorrow. I don't have time this evening.
The command you've used to checkout the libraries looks to be correct as long as the results on your computer looks a bit like so:
/develop
/develop/blender
/develop/blender/source/
/develop/blender/intern/
/develop/blender/SConstruct
compilation go well
Yes, this is exactly what has been intended. Unfortunately, it is not yet possible to specify these options in a seperate file or on the command line. I'm still working on that.
Thanks for using and testing SCons and for reporting this vital information!
With regards,
Michel
_________________
kino
Posted: Tue Jan 06, 2004 4:57 pm
-lfreetype
Hi thanks
with autoconf i ever used --prefix=/usr
in my test with scons in a previous compile i added to platform_libpath = ['/usr/lib'] mybe i forget to clear/checkout the source
can be this ?
but i removed in this compile, i dont know why is here :-/
thanks , this is in any compile since my first one (when blender/tuhopuu have autoconf Smile ) if i remember well
yes the path is like you write
With regards,
Michel
hope is usefull
thanks
kino
_________________
Jump to:
