Previous Thread  Next Thread
chat icon bf-blender / Windows (2004/01/07)
jesterKing
Posted: Wed Jan 07, 2004 6:54 am
This build has been obsoleted by a newer build
todays CVS build:
http://www.letwory.net/cvsbuilds/bf_blender_windows_20040107.zip
Again, this is build with the SCons, using MSVC7 as the compiler. It has TTF, International, Quicktime and OpenAL support compiled in. There is no game-engine, we hope to get it enabled at some point, though (keep the faith!).
New in this build:
* (new feature) A patch by me for setting the amount of processors (multi-processor support!) to use when rendering with YafRay. The button can be found in the YafRayGI panel. For now a hard-coded limit of 8 procs, can be set higher on request.
* (bug fix) The Export directory for YafRay is handled a bit different now, so it should allow spaces in the directory name.
* (progress) Displacement now works for all object types, with varying suitability (eg. curves, because of there relatively low renderface count.
* (feature) UV-mapping for displacement
* (bug fix) A small bugfix for windows, concerning the installation dir (the directory blender.exe is in). It is now recognized correctly. (by me and aphex, who pointed out some incomplete parts). This means that .b.blend is now saved to the .blender/ directory in under the directory blender.exe is installed.
* (feature) OOPS schematic menus
* (feature) CTRL comma/period hotkeys for 'median point' pivot and 'individual object centers' pivot.
* (progress) Knife usability fix.
* (progress) Code cleaning.
* (bug fix) "Character doesn't
crouch when I pull his spine downward"-bug fixed due to updated pose figuring code by hos.
Enjoy!
/jesterKing
JA-forreal
Posted: Wed Jan 07, 2004 8:44 am
Thanks Blender coders! And thanks jesterKing for this build. The displacement mapped scenes rendered in Yafray are amazing!
Erufailon
Posted: Wed Jan 07, 2004 11:50 am
Ok, I'm pretty dumb, so I posted this in yesterdays thread, but it didn't show there, so again: shadow only doesn't work with raytraced shadows.
is there a bug collecting place for cvs builds besides here? I mean I couldn't find where to post this, or if it has been posted already Confused
Jerrot
Posted: Wed Jan 07, 2004 12:19 pm
Thanks for the daily builds!! Smile
Well, there are still some little problems with YAFRAY - after exporting the XML, it doesn't find my textures. It seems to me like this is caused by the filenames of the maps without leading device letter ( e.g. C: ), it works by manually editing the XML file.
Hm, ok it almost works... YAFRAY finds the textures, but after 30% of rendering it completely crashes while processing my scene. But I guess that's not a Blender problem, it happens with a standalone call, too. Sad The example scene works fine though.
Jerrot
Posted: Wed Jan 07, 2004 12:33 pm
But when using the "Extractor" Script to export the scene to Yafray, it works !! Maybe there is something strange in the exported XML file of the new Yafray Export ? Can't find it though...
jesterKing
Posted: Wed Jan 07, 2004 12:57 pm
The YafRay support is still WIP.
Jerrot
Posted: Wed Jan 07, 2004 1:37 pm
Sure, just wanted to give you some feedback! Wink
The enormous speed of development is just unbelievable, great work!
jesterKing
Posted: Wed Jan 07, 2004 2:02 pm
Good you like it Very Happy There has been an awful lot of commits today again...!
blendermax
Posted: Wed Jan 07, 2004 3:20 pm
how the §$%§$% do you get to the displacement mapping options/button(s)???!!!!!111
edit: never mind, figured it out... or rather, modron figured it out for me Very Happy
leon
Posted: Wed Jan 07, 2004 3:26 pm
displacement mapping took me a while to figure out!
Try this: use the standard plane..... Set subsurf on, display level = 0, render level = 6, click on "simple". (beside "subsurf")
Add a cloud texture to the material: click on "disp" in "map-to" settings...
Then render!
kencanvey
Posted: Wed Jan 07, 2004 3:42 pm
also concerning displacement, adjusting "VAR" in "Map to" value adds or takes away how much the texture effects displacement, just in case you didn't know Very Happy
Ken
jesterKing
Posted: Wed Jan 07, 2004 3:46 pm
updated build, edited first post
VirtualDarKness
Posted: Wed Jan 07, 2004 3:51 pm
Hi, thanks for the build!
I'd like to share with you this simple bat file that I've put inside my blender folder (it has to be called yafray.bat) to run yafray without have to change system files..
Code:
PATH=%PATH%;c:\programmi\yafray\
c:\programmi\yafray\yafray.exe %1 %2 %3
(change c:\programmi\yafray to your yafray folder's path).
I hope it can help!
bye,
Giovanni.
_________________
http://www.blender.it - You'd better to use Firefox instead of IE! Wink
Guest
Posted: Wed Jan 07, 2004 5:30 pm
Code:
I hope it can help!
bye,
Giovanni.
Thank You! Thank You! Thank You! Thank You! Thank You!
Thank You!
It works! Now I have to do something with it!
Mr_B
Posted: Wed Jan 07, 2004 6:20 pm
JesterKing - This newer version (second Jan.07 release) of yours is not letting me save over default settings to retain the file paths. It was working just fine with your first Jan.07 release. If this is just me, could you/someone help with troubleshooting this problem.
What I have done before was: Extract files from zip to it's own folder, then copy/paste to the blender folder. This usually works for me nicely, even with the first Jan.07 release. I have also tried running this build from it's own folder and still have the same error. Any thoughts and probable causes would be most helpful.
[edit]
I've tried just about everything including deleting the .b file and the NAN folder in application data. It works fine with other builds, like I pointed out above, just not with this one. I asume I'm the only one with this problem. Anyways, even after uninstalling, re-installing this build hates me or my machine.
[/edit]
Goto page 1, 2  Next
Jump to:
