I downloaded the last CVS and wanted to try to render with yafray. If I look in the command prompt itīs always telling me:
[warning] unknown shader type blendershader
and itīs rendering only the background.
Can someone please help.
I already setted up the YFexport. Do I have to setup something else?
Thanks,
Detlef
Looks like you're using an old version of yafray - Are you sure that you've got Yafray .006 prerelease (http://www.yafray.org) installed? If so, maybe its the old yafray.bat that's screwing things up. you should delete anything called yafray.bat in your system path... Assuming that your OS is windows.
And it renders in background because it is done that way at the moment.
