Autoconf system , no TTF, No Game
link:
removed, use new builds
Log rwenzlaff :
-Changed "Simple" button to pulldown menu or subsurf type.
Paves way for additional subsurf types, and avoids confusion
where Simple is on, but Subsurf is off.
Log broken:
* Added butspace and sound menus. That's all of them now, phew.
* Very small tweaks to Sequence and Ipo menus
Log Ton:
Improved method to calculate normals for procedural textures such as
Marble, wood, clouds. Instead of the retarded (but faster
old method
it now derives the normal based on displacement of a 'nabla' vector;
sampling the texture additionally with three little offsets in x, y and z.
Code provided by Eeshlo, and gratefully accepted!
Log broken:
* Fixed a silly problem when changing the colours of the 'Neutral' button theme entry (which changed both the outline of buttons and various other grey buttons). Added a new theme colour 'Outline' and left 'Neutral' to remain, well, neutral.
Thanks Desoto for the report.
Log goofster :
added bmp.c and the new yafray files to the MSVC projectfiles
Log jandro:
Fixed unresolved symbol bprogname under win32
_________________
kino3d.com italian site
When I render with Yafray enabled, I get a window showing nothing but the world background color. I get this terminal output:
| Code: |
Starting scene conversion.
Scene conversion done.
Starting parser ...
[Warning]: Unknown attribute > has_orco for mesh
Parsing OK
Loading plugins ...
Registered basicblocks
Registered arealight
Registered globalphotonlight
Registered basicshaders
Registered blendershaders
Registered hemilight
Registered HDRI background
Registered photonlight
Registered mix block
Registered pathlight
Registered pointlight
Registered softlight
Registered spotlight
Registered sunlight
Registered sunsky
[Warning]: Unknown shader type blendershader
[Error]: undefined shader Material object ignored
[Loader]: Added pointlight light LAMP1
[Loader]: Added constant background world_background
[Loader]: Added camera MAINCAM
Using a world resolution of 0.00285714 per unit
Rendering with 5 raydepth
No anti-aliasing.
Building the bounding tree ... OK
Setting up lights ...
Finished setting up lights
Launching 1 threads for rendering ...
Rendering ...
0% 50% 100%
Threads finished
Saving Targa file as /home/ben/blender/YFExport/YBtest.tga
OK
Any idea what's happening and/or how to fix it? Thanks.
