Basic Modal Operator Script - Modal() Function Never Runs
BlazeCell
Postby BlazeCell » Tue May 21, 2013 7:44 am
I have a basic modal operator script with just some print commands to track program flow. Based on the output to the console, the invoke() function is the only one ever being run, never the modal() function, even though I have execute(), invoke() and modal() return {'RUNNING_MODAL'}.
Code: Select all
bl_info = {
    "name": "Test Script - Modal",
    "author": "BlazeCell",
    "version": (0, 1),
    "blender": (2, 66, 1),
    "location": "View3D > Mesh > Vertices (Ctrl+V)",
    "warning": "",
    "description": "Test Script Modal",
    "wiki_url": "",
    "tracker_url": "",
    "category": "Mesh"}
import bpy
class TestModal(bpy.types.Operator):
    """Test Script - Modal"""
    bl_idname = "mesh.test_modal"
    bl_label = "Test Modal"
    def __init__(self):
        print('START')
    def __del__(self):
        print('END')
    def execute(self, context):
        print('EXECUTE')
    def modal(self, context, event):
        print('MODAL')
        print('INVOKE')
def register():
    bpy.utils.register_class(TestModal)
def unregister():
    bpy.utils.unregister_class(TestModal)
if __name__ == "__main__":
    register()
Am I missing something, or is there bug in Blender 2.66.1 with modal operator scripts?
CoDEmanX
Postby CoDEmanX » Tue May 21, 2013 10:36 am
there should be no execute() in a modal operator, it isn't run.
You need to add a modal handler:
Code: Select all
import bpy
class ModalOperator(bpy.types.Operator):
    """Move an object with the mouse, example"""
    bl_idname = "object.modal_operator"
    bl_label = "Simple Modal Operator"
        print("MODAL")
        if event.type in {'RIGHTMOUSE', 'ESC'}:
            print("END")
            return {'CANCELLED'}
        print("INVOKE")
        context.window_manager.modal_handler_add(self) # add modal handler!!!
def register():
    bpy.utils.register_class(ModalOperator)
def unregister():
    bpy.utils.unregister_class(ModalOperator)
    register()
BlazeCell
Postby BlazeCell » Tue May 21, 2013 12:40 pm
Thank you so much! I have spent too many hours banging my head against the wall on how to get modal operators working. :D
Return to “Python”
