Todays CVS Build:
This CVS build has finally been obsoleted by a newer build
http://www.letwory.net/cvsbuilds/bf_blender_windows_20040123.zip
Again, this is build with the
SCons, using MSVC7 as the compiler. It has
TTF,
International,
Quicktime and
OpenAL support compiled in. The ODE-powered gameengine is now available,
no Solid yet. The build has been scanned for viruses and is found to be
clean.
Number of commits since previous build:
12 commits
* last commit
2004/01/23 03:59:54 CET
The relevant parts from the CVS commit logs:
bug fix)
raytracer fixed bug
#903 where in some cases horizontal lines would show in a raytraced render.
feature)
modelling New loopcut version, mostly by Johnny Matthews. More info at the end of this post.
bug fix)
unified render fixed specularity calculation, as pointed out by intrr.
bug fix)
unified render added clipping for spothalo rendering.
progress)
image format Targa max. size is now 8192x8192
progress)
particles Particles on a face's position are modified by the seed variable
bug fix)
armatures fixed deformation delay in animation rendering.
bug fix)
armatures bones get updated while pressing NKEY in pose mode.
bug fix)
python API fix for home directory on some windows version.
progress)
python API added set/getSize to the Object module.
progress)
python API In the Armature/Bone module bone.set now accepts both n floats or a list of n floats
As promised a little more on the new loopcut version:
new features:
- after choosing a loop to cut you go into a second mode that lets you choose where exactly on the edge you want to cut.
the placement is in percentages, so 0% is one side of the edge, and 100% is the other side.
- holding CTRL snaps the placement to whole percentages. 1.00 instead of the standard 0.01 of a percentage.
- Pressing S while you place the cut turns on Smooth-subdivide for the cut (or as I like to call it: Loopcutsubdividesmooth
- the percentages and the ON/OFF for smooth cut can be seen in the view3D header.
fixes:
- loop takes into account hidden vertices, this solves bug
#895.
- Cutpreviews are drawn correctly for triangular faces.
- renamed the function from loop -> loopoperations. I'm sure someone has a problem with the new name too, but BLAH!
- the parameters for the function are defines. loopoperations(LOOP_CUT) cuts, and loopoperation(LOOP_SELECT) selects (duh). this is changes in all the places the function gets called.
Enjoy!
/jesterKing
I'd been anxiously awaiting the new loopcut functionality being added to the bf-blender. I've tried it in tohuapu (spelling?) and loved it. Thanks again jesterking for all the builds.
Thanx For every build.. jesterKing.
From many time there is no interesting commit on yafRay front.. we are waiting for..!
The scripts in menus STILL don't show up unless I write a custom python path. The Blender/Scripts folder has quite a few scripts in it. I thought it should automaticly searh in Blender/scripts for any AS WELL as the Python path..
Anyone else experiencing the same thing?
_________________
Website:
http://www.shadeless.dk
Blender writes this when I open:
| Code: |
Expected default dir in C:\Documents and Settings\Administrator\Application Data
\Not a Number\Blender\.blender\scripts\ . |
It looks to me like the path is absolute, not relative as it should be.
Oh and it still doesn't recognise the python path if there is a "\" at the end (which there is by default)
_________________
Is the light DIST slider maxing at 100 a permanent feature? How do we set a dist above 100? If I shift click and type in a value greater than 100 it resets back to 100. How do you change the effective dist beyond this then?
I have tried scaling the light and this does draw a longer dist indication in the 3D window, but doing this does not affect the HALO at all.
Again i got this when compile with your lib:
| Code: |
ftgl_static_ST.lib(FTPixmapGlyph.obj) : error LNK2001: unresolved external symbo
l __ftol2
blender.exe : fatal error LNK1120: 1 unresolved externals
scons: *** [blender.exe] Error 1120
If you don't know it's okay, look like scons isn't ready to be used by the community anyway...
Well...The Game engine works, except the framerate is about 1/3 of what it is in blender 2.25. Plus, the dloc works fine, but the LinV does not. Why is this? Also, great job jesterking, thank you for your daily updates.
_________________
He who laughs last thinks slowest.
Visit L3D for cool 3D stuff!
Home of Legacy of Taro, the 3d action/adventure samurai game.
What about a feature, when you close blender and your file isn't saved, a window popups and ask you to save or just quit. I always save before I quit, but there are times that I quit blender without saving, and then afther it think about "did I saved it?"
Whatever happened to wireframe view in face select mode?
TorQ
Thanks for the Daily Builds!
