Tuhopuu / Windows (2004/01/26)
nozzy
Postby nozzy » Mon Jan 26, 2004 5:52 pm
This is a old build, check newer posting
For your enjoyment ;)
tuhopuu-2004-01-26-windows.zip
Check the logs for updates:
logs-january
phase
Re: Tuhopuu / Windows (2004/01/26)
Postby phase » Mon Jan 26, 2004 8:30 pm
nozzy wrote:Check the logs for updates:
logs-january
Unfortunately, my recent commits aren't included in these logs. :(
Please note however; a very nifty mesh tool got comitted to Tuhopuu,
which was written and submitted by Spectr.
From Tuhopuu's featurelist.txt:
Code: Select all
Added union mesh tool submitted by Spectr.
CTRL-V in editmode allows you to modify the edges of adjacent faces.
You can choose how the two faces should be connected, or change two triangles into a quad face.
It propery handles UV, material and vertex color data of the modified faces.
Useful for cleaning up meshes after a boolean operation.
This function has 3 modes, with toggle keys: (info appears in windowheader)
SHIFT Click - loop or single selection;
CTRL Click  - convert adjacent triangle and quad into: triangle, or quad;
ALT Click   - convert adjacent two quad into: triangle, or quad.
Just thought I'd post it here so it won't be missed.
Rob.
Caronte
Postby Caronte » Mon Jan 26, 2004 11:07 pm
Anyone know why the randomize vertex effect are missing on the latest tuhopuu builds? :( It's very usefull!
Caronte.
http://www.nicodigital.com
Monkeyboi
Postby Monkeyboi » Mon Jan 26, 2004 11:17 pm
Yeah, Tohupuu seems to be loosing features. Strange.
theeth
Postby theeth » Mon Jan 26, 2004 11:46 pm
Some functions were never ported from tuhopuu 1, or we removed in a make over or a code cleaning or whatnot. You have to remember that tuhopuu is a coding playground, not a stable release. There's no garranty that tools won't change one day or new functions that will invalidate others.
Martin
- John Lennon
Caronte
Postby Caronte » Tue Jan 27, 2004 12:08 am
I think this feature is a must but like ever it's just my personal opinion.
Edited:
Well I found a posible cause to remove this feature:
The displacement mapping can do the same work with a noise texture also is far better :D
Caronte.
nozzy
Postby nozzy » Sat Jan 31, 2004 10:50 am
Sorry for the lack of new builds, but I'am having problems building Tuhopuu.
I updated my CVS as usual but the compile stops with this:
Code: Select all
make[3]: *** [/home/RobertIves/tuhopuu/tuhopuu2/obj/windows/blender/src/space.o]
 Error 1
make[2]: *** [all] Error 1
make[1]: *** [all] Error 1
make: *** [all] Error 1
And no .exe in the bin folder? :(
I've tryed everything but re-installing Cygwin, anyone any ideas?
Michel
Location: Somewhere below the rivers in Holland (but not Limburg)
Postby Michel » Sat Jan 31, 2004 1:35 pm
nozzy wrote:I updated my CVS as usual but the compile stops with this:
Code: Select all
 Error 1
you've pasted the least important information :wink: The error on what really went wrong is above the lines you've pasted here. Without that information I have no idea what is wrong.
With regards,
Michel
You can have one of two things: Progress or Progress Reports.
nozzy
Postby nozzy » Sat Jan 31, 2004 3:25 pm
Michel wrote:you've pasted the least important information
Opps :oops: , hope this makes thing little clearer :)
Code: Select all
space.c: In function `winqreadview3dspace':
space.c:674: error: `WHEELLEFTMOUSE' undeclared (first use in this function)
space.c:674: error: (Each undeclared identifier is reported only once
space.c:674: error: for each function it appears in.)
space.c:705: error: `WHEELRIGHTMOUSE' undeclared (first use in this function)
space.c:1508: warning: implicit declaration of function `union_mesh'
space.c:573: warning: unused variable `mval'
space.c:573: warning: unused variable `i'
space.c:573: warning: unused variable `j'
space.c: In function `winqreadipospace':
space.c:1776: error: `WHEELLEFTMOUSE' undeclared (first use in this function)
space.c:1777: error: `WHEELRIGHTMOUSE' undeclared (first use in this function)
space.c: In function `winqreadseqspace':
space.c:3165: error: `WHEELLEFTMOUSE' undeclared (first use in this function)
space.c:3166: error: `WHEELRIGHTMOUSE' undeclared (first use in this function)
space.c: In function `winqreadoopsspace':
space.c:3704: error: `WHEELLEFTMOUSE' undeclared (first use in this function)
space.c:3705: error: `WHEELRIGHTMOUSE' undeclared (first use in this function)
 Error 1
Thanks.
/nozzy
bjornmose
Postby bjornmose » Sun Feb 01, 2004 1:42 am
i think kester has to fix that ?
Return to “Testing Builds”
