Previous Thread  Next Thread
chat icon OpenGL artifacts in 2.32 Render
postman
Posted: Thu Feb 05, 2004 7:17 am
In the new 2.32 version, I opened a file I had been working on in 2.31a (and earlier) and rendered it. The Artifacts that show up on the OpenGL shaded view in the 3D workspace also were rendered--which I thought was quite weird. That has never happened in any previous renders under any other version, right up to 2.31a.
Has anyone else seen this? I used the default 2.32 "factory settings". I tried different things to correct it, but no success. Any ideas?
Thanks!
SirDude
Posted: Thu Feb 05, 2004 5:11 pm
Could you post the blend file on the web so we
can take a look at it?
postman
Posted: Fri Feb 06, 2004 1:21 am
Hello again.
Maybe it's a backwards-compatibility problem? In the 2.32 render, I tried just rendering with the factory settings and the regular Scanline renderer. I tried Gauss, and other settings--all did the same thing. Again, first time this happened is in 2.32. v2.31a worked fine. I posted some pics to illustrate:
http://jlillis99.tripod.com/Artifacts.htm
The .blend file is a little big and I'm on dialup. Let me know if it you still need it after looking at the pics.
Thanks! Smile
solmax
Posted: Fri Feb 06, 2004 2:35 am
looks like a normals-problem to me. try CTRL+N in edit mode with all vertices selected to recalculate all vertex normals to sow outside.
greets
marin
postman
Posted: Sat Feb 07, 2004 3:00 am
Thanks! That did the trick.
I LIKE 2.32 NOW.... Smile
Jump to:
