Armature proposal
Monkeyboi
Armature proposal
Postby Monkeyboi » Thu Feb 05, 2004 12:39 pm
I have made a proposal on how to improve armatures visually, and make them slightly easier to approach. It's no huge overhaul, but merely something small that will improve them quite a bit. Here it is:
http://www.shadeless.dk/ui/armatures.htm
Tell me what you think!
-William
dreamsgate
Postby dreamsgate » Thu Feb 05, 2004 2:38 pm
That looks like a good idea. Personally I have never used constraints or IK because I can't quite figure out how to set it up. Your method would at least give me an idea of where to start.
Sorry I'm not a coder, so I have no idea how hard it would be to do.
solmax
Postby solmax » Thu Feb 05, 2004 7:13 pm
hm, actually why not. anyway i'd rather like NLA implemented for ALL objects. right now i don't use the "common" technique for using bones as ik constraints, simply because of the unsexy ;) visual representation and because of too much ctrl-tab switching when animating NOT only armatures. instead i have custom made controlling objects, which are not rendered in the final render.
speaking of visual representation - how about transform handles? i remeber this idea popping up somewhere in the forum. i appreciate blenders simplicity and straight-forward interface, but transform handles would be a great help.
Hos
Postby Hos » Sat Feb 07, 2004 10:32 pm
In tuhopuu1 (in my local copy that I never committed),
I created what I called 'bone glyphs':
http://bebop.cns.ualberta.ca/~cwant/glyphs.jpg
There were controls for altering color and for
style/shape (polygon/stars/asterisks, each
with a 'number of sides' setting). The shapes
would always face the camera so they were
easy to see. In the example, I have color
coded by finger and used similar shapes to
indicate similar knuckles. Auto-IK was set up to
create glyphs for the automatically generated
control bones.
They're ugly, but I think they give some helpful
visual cues. One day when I'm bored I'll revisit
this again ...
Chris
Monkeyboi
Postby Monkeyboi » Sun Feb 08, 2004 12:08 am
Hi Chris,
That looks great, although a sliglty more 3d-ish look might be better, so that it is easyer to see its rotation on all the axes. Coloring would be interesting.
What do you think of the auto IK idea integrated into the toolbox Add menu? I think this would really boost the armatures usability..
Monkeyboi
Postby Monkeyboi » Sun Feb 08, 2004 12:24 am
Here is what the bone nulls look like in Softimage XSI:
This is a differemt type of null, for animationg torso's etc:
The torso null moved:
The torso null moved again:
Maybe it would also be nice to add an inbuilt armature rig with lots of nice controls for feet and arms. That could also by in the Add>Armature menu as well as 'IK Chain', 'FK CHain' and 'Null'. It could be called 'Human Rig' or something.
pildanovak
Postby pildanovak » Sun Feb 08, 2004 10:44 am
in this thread is another idea about what could be called "muscle chain", and would be very useful for advanced rigging if a separate type of bone chain.
http://www.blender.org/modules.php?op=m ... pic&t=2821
Money_YaY!
Postby Money_YaY! » Sun Feb 08, 2004 4:33 pm
Hos wrote:In tuhopuu1 (in my local copy that I never committed),
control bones.
this again ...
Chris
I think they could be useful as an option, It could help a bit now and then when things get to messy. Please add it. Also, for BF can you add the auto IK that would be helpful not having to jump between Tuhopuu and BF just for the one little feature for quick tests?
Other than that. How about a mesh Skeleton ? Like a shell of the mesh model that at it's mesh joints would be the defining joint rotation spot. It could be useful as visual and it could be weight painted. It would remove the ugly opengl armature look. And would launch blender more towards the looks of the higher external animation programs. All of this while being much easier to visulize how to pose it.
Should I make an example jpeg ?
theeth
Postby theeth » Sun Feb 08, 2004 4:39 pm
Money_YaY! wrote:Should I make an example jpeg ?
yes
Martin
- John Lennon
Money_YaY!
Postby Money_YaY! » Mon Feb 09, 2004 5:10 am
Simple old thing I have wanted to use this feature with.
But to go in depth, at each break the joint could be formed. Basicly every thing works as normal it would use the same armature code. But instead of the hard to read wires of armatures, it would be controled by the rig mesh.
Or it could be like an invisible armature in side of the rig mesh.
Does it sound stupid theeth ?
theeth
Postby theeth » Mon Feb 09, 2004 3:22 pm
So basicly it's just changing how the armature looks?
Martin
- John Lennon
Money_YaY!
Postby Money_YaY! » Mon Feb 09, 2004 4:53 pm
theeth wrote:So basicly it's just changing how the armature looks?
Martin
Yeah. Of course it would be nice to have new stuff to, but for now that would be enough to help the eyes focus. Can it be done ?
Monkeyboi
Postby Monkeyboi » Mon Feb 09, 2004 5:39 pm
Changing the looks of the armatures to look more like real human bones sounds hard to do (how do you tell it what is what etc?).
I think it is more important to start with something more needed. The torso null stuff I showed from XSI isn't that important to have. Better to just have a regular spherical null to start with. Ofcourse, maybe in the edit buttons you might be able to choose the look of the null (spherical, 2d star, circle, plane etc).
I once tried a Tohupuu version which had auto IK in it. This was great, but as I remember you had to hold down a key to activate it while adding bones. Surely it would be more usable if were in the Add>Armature menu.
Money_YaY!
Postby Money_YaY! » Mon Feb 09, 2004 9:01 pm
Monkeyboi wrote:Changing the looks of the armatures to look more like real human bones sounds hard to do (how do you tell it what is what etc?).
It would just be blocks or the mesh cut up into joining peices. As for auto IK, it was only after you were done with creating the chain, you select the very last bone and press alt+i . Simple perfect for tests.
The problem with the OpenGL IK draw bones, is that when you get to ti many skinney line every where it gets relly hard to se what is being selected and moved..
theeth
Postby theeth » Mon Feb 09, 2004 10:15 pm
Just parenting boxes to the bones would have the same effect.
Martin
- John Lennon
Return to “Animation”
